Introduction: Take Paint Off of Models
This article shows how to take paint off of old models so that you can repaint them. You might want to do this if you buy used painted models and want to paint them yourself. If you want to sell them, taking the paint off and priming the models can make them look more appealing.
I did this because I had bought some painted models from a friend that I wanted to repaint. I was lucky and the models were not primed, as this makes the process more difficult. I also had some Tau models that I had painted about 4 years ago, and wanted to paint them again. I couldn't just paint over the old paint because when I had first painted the models I used way too much paint. The first coat of paint had filled all of the cracks in the model and obscured most of the detail.
Step 1: Materials
- Simple Green all-purpose cleaner
- old toothbrush
- toothpicks
- a tub for water
Step 2: Soak the Models in Simple Green
If you have time to let the model soak for a while, mix the simple green with water.
I needed about 750ml of cleaner to cover half of my tank, because I could flip it and soak again. I used a ratio of water to cleaner of 2:1. The soak time estimates in this guide are using this mixture. Soak the models in a tub or bowl that you dont care about.
Completely submerge you models in the cleaner for about 24 hours. The longer the models soak the easier the paint comes off. You will be able to scrape the paint off after only 3-4 hours, but it will be much easier after 24 hours. Leaving the models in for too long should not harm them. I left a few in for 2 weeks to make sure, and they are fine. Simple green also weakens dried super glue. Any "green stuff" will easily come off after soaking. The picture below is after soaking before any scrubbing. I wrapped the tub in plastic wrap so the simple green wouldn't smell as much.
Scrub the models right after they come out of the cleaner mixture.
Step 3: Scrub the Model
First use an old toothbrush to get the majority of the paint off of your model, occasionally rinsing the model in a tub of water. Don't work at this step for too long, just get most of the paint on the exposed faces off. The first picture is after about a minute of scrubbing.
Don't leave the models out of the cleaner mixture before taking all of the paint off. The paint will dry back onto the model after a few hours.
Step 4: Pick at the Model
This part can take a while. Just scrape at the model with a toothpick until it gets too dull. On the four models you see below I spent about 2 hours picking at scraping and picking at them. Its time consuming but easy. It can be done while listening to music or watching a movie( LOTR in my case). Focus on the areas where the paint really covers up the model's detail. You can use pins or needles instead of toothpicks, but they can scratch the models.
Step 5: Your Done!
You can now repaint the models (see below), or sell them for much more than you could a model covered in paint.
If you want to go one step further you can also take apart some models. While simple green helps, I found that putting models in the freezer really helps with taking apart models made of metal. The glue becomes brittle and the model easily comes apart. I also tried this with plastic models, but im not sure if the weakened glue was from the simple green or the freezer.
