Introduction: Take-out Cup Greenhouse
Learn how to make a simple greenhouse for your seedlings using nothing but an old plastic cup! This is a great way to reduce your environmental impact and improve the quality of your young sprouts!
A clear plastic cup with a lid
Potting soil
Seeds or seedlings
Step 1: Clean Cup
Rinse the cup of any left-over beverage
Step 2: Add Dirt
Fill the cup about halfway with dirt. Make sure to leave room for your plant to grow underneath the lid.
Step 3: Add Seed or Seedling
Make a hole in the dirt and transplant a seedling or plant a seed of your desired plant. Water the plant lightly. Be careful not to over-water as water will not evaporate as easily from this container. In the images you can see the dirt with a small divot and the transplanting of a basil seedling.
Step 4: Attach the Lid
Put the lid of the cup on and place the container in the sun. The straw hole will act as a vent, helping to prevent the plant from overheating and allow CO2 into the space to replace what the plant uses. Water as needed, but this will be less often than a traditional planter. You should see water condensing on the walls of the cup within a day. This is your very own micro-climate forming within the greenhouse! When the plant is bigger, transplant it to a container of your choice or simple remove the lid and allow the plant to grow out of it.
Planter Challenge
4 Comments
3 years ago
Seedling usually dont require such a large space, but pretty nice and common reuse project
Reply 3 years ago
A smaller cup may work better if you don't need as much space, but I just used what I had. Thanks!
3 years ago
Such a great reuse project :)
Reply 3 years ago
Thank you!
