Introduction: Tang Survival Kit
I have seen a lot of survival kits on this site. Most of them are all contained in a altoid tin. I think that they are missing a few items that would make them more affective. Anyways here is mine. Let me know what you think or if I am missing something.
Step 1: Things Needed:
I will explain what each one does.
Here is the list:
1- LED Flashlight
3'- 12 gauge stranded wire with sheathing removed
1- Simple knife
30' - String
1- Box of waterproof matches
1- Magnesium flint
3- Nuts
1- Bottle of Iodine tablets
5'- Duct tape
1- Platsic grocery bag
1- Ziplock baggy
1- 3'X3' sheet of tin foil
1- 1'X3' sheet of saran wrap
1- Ball type compass (they're smaller than most and work better than most of the cheapys)
1- Large needle
1- Replacement sling shot strap
1- Condom
1- Hand sanitizing wipe (individual packet type)
1- Razor blade ( I made a small cardboard sheath for it)
1- Emergency Blanket
1- 3'' piece of plastic tubing
1- Butane lighter
1- Smaller container containing cotton balls covered in petroleum jelly and dryer lint.
1- Small bag of char cloth (not pictured)
1- Fishing kit (Contains: 2 mini bobbers, 2-20' folls of 8 lbs fishing line, 1- 20' roll of spider wire fishing line, and a assortment of small hooks. They all are kept in a 35mm camera case).
Here is the list:
1- LED Flashlight
1- Simple knife
30' - String
1- Magnesium flint
3- Nuts
5'- Duct tape
1- Ziplock baggy
1- Large needle
1- Condom
1- Butane lighter
Step 2: Fire
The magnesium flint, lighter, water proof matches, char cloth, cotton balls/ lint are part of your fire making part of the kit. I don't think I need to tell you what they do.
Step 3: Hydration
The tang container, condom, Iodine tablets, plastic tube are hydration part of the kit. The tang container can be used as a cup or bowl or both (top and bottom). It can also haul water because the top screws on. The condom is also a way to carry water. It can hold up to a gallon of water for storage (this item if found on the internet). The plastic tube can be used to drink water out of small puddles or even the condom! haha
Step 4: Hunting/ Food
Wrist rocket strap, string, wire, fishing kit, nuts are the food/ hunting portion of the kit. The strap can be attached to any Y-shaped stick to give you a decent weapon for hunting. The wire can be unwound to make a whole bunch of snare wires or used to lash things together. The string can be used the same way. The nuts are just a couple of almonds I added to use as bait. Probably don't need it but it is so small..why not.
Step 5: Misc.
The remaining items are more miscellaneous:
Duct tape- can be used as a bandage, fixing thinks, etc.
Needle- can be used for fixing clothes, skin, etc.
LED flashlight- I like the LED type because they are small, they don't draw a lot of power, and you cannot break the bulb! I have also seen somebody make a fire with one!
Compass- Find your home!
Emergency Blanket- Keeping you warm
Grocery store bag/ ziplock bag- Holding water, items, many different things
Hand sanitation wipe- Cleansing hands, wounds, etc.
Tin foil- cooking things
Razor blade- conserve on knife blade,etc.
Saran wrap- bandages, collecting water, million of uses
Knife- swiss army knife is what i have...has toothpick, tweezers, etc.
Step 6: Done
That is it all put inside the container...
Thanks for lookin
Thanks for lookin
