Tape Measure Yagi Antenna With 3D Printed Couplers
Intro: Tape Measure Yagi Antenna With 3D Printed Couplers
My take on this classic design uses pieces of standard tape measure steel as radials, a 1-inch diameter PVC pipe as the mast, and 3D printed couplers to link the radials to the mast. I built this 2m band antenna to listen to satellites.
STEP 1: 3D Printed Couplers
I modeled the couplers using Tinkercad, first by creating stand-ins for both the mast and the tape measure, then forming solids to join the two and grouping everything together. After making this long version I shortened it so the couplers could be closer together on the mast, and created a few versions for the end cap and driven element couplers. I printed the rainbow of parts on my Creality CR10s-pro using 20% infill. You can copy the design on Tinkercad or download my STL files directly from this step.
Disclosure: at the time of this writing, I'm an employee of Autodesk, which makes Tinkercad.
STEP 2: Assemble the Antenna
I followed 2m band specs I found online for the length and spacing of the tape measure pieces. I'm far from the first person to make one of these, and here are the designs I researched:
- Joe Leggio WB2HOL Tape Measure Beam Optimized for Radio Direction Finding
- Michael Martens' 2 meter Tape Measure Yagi Beam Antenna
- South Canadian Amateur Radio Society's Tape Measure VHF/UHF Yagi Antenna
- jcoman's Tape Measure Antenna
The driven element pieces are connected both to each other with a wire folded into a hairpin shape. I sanded off the paint from the tape measure steel where I wanted to solder and connected the driven elements with a piece of wire bent into a hairpin shape as well as the two parts of the coaxial cable.
STEP 3: Hardware & Software Setup
I'm using this software-defined radio USB dongle to connect the antenna to my computer running CubicSDR, a free app that is cross-platform and open source. Inside CubicSDR, I can see a waterfall display of the spectrum and I can move around to look at and listen to different frequencies. If you're new to this setup, play around with the small dipole antenna that comes with the SDR unit first. You can tune to your favorite local FM radio station to start, or try finding your local NOAA weather broadcast station, which will also supply a constant source of audio. Then try to tune to your local repeaters, which will only be visible on the display when they are transmitting, which isn't necessarily all the time.
STEP 4: Trying It Out
Once I got up on the roof I remembered to tape the ends of the cut pieces of tape measure for safety. I used the Heavens Above android app to look up and track satellites with downlinks operating in the 2m band and had a go at pointing the antenna while setting the frequency on the computer. It's hard to do both at the same time so I got some help. We didn't really get any results that first time out, so I borrowed a friend's nanoVNA to try to check and tune the standing wave ratio of my antenna. I first set it to sweep between 144 and 148Mhz, then calibrated it using the included open, short, and load nubbins. I tuned my antenna by adjusting the spacing between the driven elements and the shape of the hairpin wire. We're going for as close to 1 as can be managed here. Back up to the roof to try again.
STEP 5: Partially-Successful Results
The satellites I ended up being able to hear the best were NOAA weather satellites, which transmit an analog picture signal containing satellite images that can be decoded from the recorded audio file. My best attempt so far only had a small area that wasn't static, but you can see with the map overlay and compared to the full satellite image I looked up online, I've got a partial result here. It's so cool that signal came from space! I used noaa-apt software to decode the images.
Thanks for reading! To keep up with what Iām working on, follow me on YouTube, Instagram, Twitter, Pinterest, and subscribe to my newsletter.
Related projects:
30 Comments
alpha1138 3 years ago
BobDakotanBRJ 2 years ago
Or you could just try to position the antenna so the breeze is pushing the arms straight instead of curling them up--might be your easiest solution.
For an all weather design you could use angle-iron shaped pieces for the arms (probably aluminum would make sense) and use a big enough pipe to nest all the pieces inside for storage. Since I don't have a 3-d printer I'd just use pvc x fittings for brackets and attach the arms with a set screw. Or you could find 3 pieces of pipe that fit one inside the other. (EMT conduit comes to my mind, 1/2, 3/4 and 1 inch sizes, and it would all fit in a 1-1/4 inch PVC pipe for the center staff piece. Go with schedule 80 pvc conduit for extra toughness.). Have fun!
JohnW51 2 years ago
Gomez Addams 3 years ago
jimvandamme 2 years ago
If you can't deal with the rigidity problem, make antennas the old-fashioned way, with rigid tubing elements. Of course it needs a plane to store it against (wall or ceiling) but the hard part is transporting it.
ELECTRONFLYER1 3 years ago
JohnW51 2 years ago
JohnW51 2 years ago
grapenut 2 years ago
ZaRue 3 years ago
https://www.amazon.com/dp/B06Y1HKLHY/ref=cm_sw_em_r_mt_dp_T0MK238W6YBY5C2925KC?_encoding=UTF8&psc=1
mcshrade 2 years ago
AlexanderS290 3 years ago
if you order something like that it will be compatible with most if not all SDR type software. (and i dont give you a recommendation because its often personal preference what to use.) the option to use "virtual audio cables" or even real ones or audio recordings to feed those data into sub-programs for special decoding purposes is a thing mentioned in the presentation as well - so dont miss it.
PS: dont forget to order a RF cable that matches your receiver dongle at one end. the other will be anyways cut off as you can see in the video. (i am not sure if it would make sense to give the antenna a socket on its own but it should be a not to bad and feasible option.)
K1YBE 3 years ago
bekathwia 3 years ago
Sigma Toot 3 years ago
What an inspirational concept! At the tender age of 66, I've still got the same enthusiasm for technology as when I took my first b&w 405-line TV to bits ... this sort of project is *exactly* what's needed to encourage more uptake in STEM.
Fantastic! - keep up the good work.
PS - my user name alludes to my garage i.e. 'Sigma' (the sum of) plus 'Toot' - a weird North of England word that my wife uses to describe all those 'interesting & potentially useful' things I hoard (and which most other people would throw away) šš
Sawadeee 3 years ago
PS. Narrators voice was perfect.
ANDRELAS 3 years ago
mcshrade 3 years ago
you should have been in USB. Those signals were actually very good considering they were from space, so the antenna is working quite well!
