Introduction: The Tape Measure Antenna
Are you looking for an easy kid friendly project? Are you looking for a project to encourage a new generation of ham radio operators?
This project is unusual, so it’s something that will certainly capture the attention of anyone, particularly a kid. It’s an antenna built out of PVC pipe, a tape measure and a handful of hose clamps.
This antenna is designed for two-meter operations, which, for a newbie ham operator, is one of the bands available under the Technician license in the US. Plus it’s easy to build and gives a great opportunity to teach several subjects with a hands-on approach.
Disclaimer: This project isn’t new; it’s not even my idea or design. I used the design from Joe Leggios (WB2HOL). The plans to his antenna are here.
Project Background
My nephew recently expressed interest in earning his Technician class amateur radio license. While some people discount the Technician level license of amateur radio as “ridiculously simple” (including a well known conservative talk radio personality) it’s not so easy for an eight-year old. It requires comprehension of concepts that they still have yet to cover in school. Topics like basic algebra and principals of electricity.
When I set out to find a project, I was looking for something unusual that would grab his attention but something that was easy, fast and required few tools or skills. And I wanted it to be cheap. There is a total of $20 in materials in this antenna, assuming everything is purchased specifically for this project and not scavenged or salvaged parts.
The fundamentals of antennas is the one area I’ve been finding difficult to teach my nephew. Mostly because I refuse to “teach the test”. I want him to fully understand the material, not just pass a test. And I have found that I have had to teach him basic algebra in the process.
This project was perfect as I could scale it up or down as a lesson in a number of ways. Which is to say you can use the plans to build a perfectly workable antenna, or, you can use the formula for a Yagi antenna to modify the design. In my case, my nephew and I used the plans from WB2HOL, but we worked through the math to come up with element lengths.
And, in the end, we built something useable for when he earns his Technician class license.
Materials List
3/4” Schedule 40 PVC Pipe - at least 25”
6 hose clams big enough to fit around the PVC pipe
1 3/4” PVC tee
2 3/4” PVC crosses
8’ RG-58 cable with a connector attached to one side. I soldered a female BNC to mine.
5” wire. I used 18 gauge solid copper wire, but I’m told anything works.
Rosin core solder
Tape measure with 1” wide tape
PVC glue
Tools Needed
Soldering iron
Tape measure
Pipe cutters
Wire stripper
Shears or scissors
Sand paper
SWR Meter
Screwdriver or wrench for tightening the hose clamps
Step 1: Cutting the Elements and Assembling the Boom
You’ll need to cut two pieces of PVC pipe. One piece will be 17 1/2”. The other 7”. This, along with the PVC connectors, will form the frame of the antenna.
Assemble the pipe to form the frame ("boom") of the antenna. Gluing each piece together, the 17 1/2” piece connects between the tee and the first cross. The PVC tee is the front of the antenna. The 7” piece connects between the first and second tees.
Disassemble the tape measure by pulling the tape out of the case. If you pull the tape past it’s end, you’ll find that it’s connected to a spring. Simply twist the tape so it disconnects from the spring.
Cut the tape at 35 1/8”. This will be the director of the antenna and will attach to the front of the antenna.
Cut two 17 3/4” long pieces of the tape. These will serve as the driven elements.
Cut an additional element from the tape. This will need to be 41 3/8”. This is the reflector element.
Sand all the ends of the elements so they are smooth to the touch. These are extremely sharp if left un-sanded. Also sand off about 1/2” of paint on the ends of the bottom side of the driven elements. This will be where you will solder the wires later.
Note: If you are going to mount the antenna, set it up so the antenna will be forward of the mounts. Yagi antennas may suffer in performance if mounted elsewhere, like the center of the boom.
Step 2: Installing the Elements of the Antenna
Slip the hose clams over the PVC tee at the front and slip the Director element under it. Tighten the hose clams so it is secure.
Attach each of the driven elements to the frame of the antenna with the sanded sides facing each other. Before securing the elements, space the elements 1” apart and tighten the clamps.
Finally, attach the reflector element at the rear of the antenna and tighten the clamps.
Step 3: Soldering the Wires
Now you will tin the ends of the driven element. Simply heat the soldering iron and apply solder to the tape measure at the sanded spots. Make small pads where you can solder two wires to each side of each driven element.
Strip the end of the RG-58 cable and isolate the outer and inner wire. Solder one side of the RG-58 to a driven element and the other to the opposite driven element.
Strip the 5” piece of 18 gauge (or whatever wire you have) and solder a side to each of the driven elements.
I chose to add an optional piece of PVC and an elbow at the rear of the antenna to make it easier to hold and/or mount. I also chose not to glue the PVC together so the antenna can be broken down for storage.
Step 4: Adjusting the Antenna
Adjusting the antenna is very simple. Simply attach a SWR meter between the antenna and the radio. Adjust your radio to 146.580 mhz and check your SWR reading. If the reading is more than 1.2 to 1, turn off your radio and adjust the driven elements by loosening the hose clams and moving the elements toward each other. Turn on your radio and check your SWR again. Repeat until your SWR is at an acceptable level. I was lucky and my antenna registered extremely close to 1 to 1 without adjustment.
When adjusting the driven elements make sure your radio is off.
Step 5: Technical Notes
Software modeling programs show that this antenna should have a gain of 7.3 dBd.
Real world experience: Running a HT at 5 watts, my nephew and I were able to use a repeater 65.7 miles away, with reports of a clear signal. We were also able to access several other repeaters that are 40 to 50-miles away. Performance will vary based on your location.
While this antenna is designed for VHF two-meter operations, it can easily be redesigned for other frequencies like 1.25 meter, 70 cm or 33 cm. There are many websites that will calculate the length of and length between the elements on a Yagi-Uda antenna. You can try Martin Meserve's (K7MEM) online calculator here.
Additional information on this antenna
The original plans for this antenna are available at Joe Leggios (WB2HOL) website. A link to the plans is here.
Additional plans are available from KC0TKS' website here, as well as from NT1K's website here.
Workshop Contest
7 People Made This Project!
- feedthemonkey made it!
- tr00st made it!
- YO2LIG made it!
- Joel29 made it!
See 3 More
30 Comments
3 years ago
I could have sworn I posted this a long time ago... There is a typo in the lengths of the PVC pipe pieces. The long one should be 11 1/2 inches, not 17 1/2 inches. OP must have confused it with the 17 3/4" driven elements. Oops!
6 years ago
How do you attach the coax cable to the elements? Do you use the metallic shielding that has been twisted into 2 strands? YOu are not showing a connector in the picture.
Reply 6 years ago
You sand off a section on the driven element, flux it and tin it with solder. You seperate the conductor and outer stranded shielding, making them into a Y shape ( being careful to not let them touch eachother) and solder them to the areas you just cleaned and soldered.
6 years ago
Would this work as a good fm radio antenna?
Reply 6 years ago
Yes, but you need to make some modifications to improve its gain. It's tuned for the amateur band so you need to cut the elements for the FM band to optimize the recieve. It will work good as-is on recieve but, if you are looking to build the highest gain antenna you can, you should build it with shorter elements. Your driven element should be around 57.25", your reflector element should be 58.125" and 53.125".
Remember that its a directional antenna, so you will only recieve stations pretty much in the direction its pointed.
6 years ago
I need to know if I could use something like this on a cubesat
Reply 6 years ago
Sure, lots of people do.
6 years ago
I decided to make one of these, I love in Australia, and to buy everything needed it has cost me a total of $80-90AU ($50-60US?)
I hate how expensive simple stuff is in this country ;_;
6 years ago
Mr. Coman, Great post! My question is, does it matter what the length of the feed line is? I am using 8x and thinking of about 10’ not counting the choke wrapped around the mast. I would very much appreciate your wisdom on this. Thanks! Scott KW4JM
Reply 6 years ago
The length doesn't matter on the coax. I used 8 feet just because its what I had handy at the time. There is so little attenuation in two feet of feedline that you'll never notice it.
Reply 6 years ago
Thanks. Helpful again.
7 years ago on Introduction
Hello, jcomen. I have been searching for a way to "redirect" 3G cellphone frequencies from the outside into my room both for my cellphone and my internet pendrive. I work on hydro-power projects far away from any towns and inhabit a (pretty good) housing container for most of the year. The thing is that both outer and inner walls are made of metal sheets and everything is grounded because of the electrical instalation and lightning protection, almost making my room a perfect Faraday cage ! I was thinking of building an outdoor "receiving" antenna and running a small lenght of coax cable to a "broadcasting" antenna inside the room without using any sort of power, a passive device.
Since this sort of knowledge is way off my league can you help me with any ideas ?
Have you tried contacting a satellite, or the ISS? I would like to know to see if I could build one of these so I could try contacting NA1SS (the American part of the ISS.)
Safety feature: The locals that have used these for transmitter hunt antennas for the last decade or so discovered something a long time ago... The edges of the tape measure section can be VERY sharp and can cut a gash faster than you can blink. I'd do two things: first, use a file on the sharp ends to reduce the sharpness as much as possible... Second, cover the ends with something - the most common thing you see around here is a piece of cloth duct tape folded over each end of each element.
BTW, if you have a Harbor Freight in your area, walk in and sign up for the snail-mailed coupons Every so often their monthly snail-mail flyer includes a coupon for a free 25 foot (by 1 inch) tape measure just for walking into the store (no purchase required). Two other frequent freebies are a low-end-DVM or a 6-piece screwdriver set (both of which live in my ARES go-bag).
8 years ago on Introduction
Ive seen a number of antennas such as this. Im curious where and why the 5" piece of wire is used. Is the wire a matching section or impedance balance component?
You are absolutely correct, it's a hairpin match. It's the simplest match for this type of antenna, with the added bonus that it is light weight and compact as compared to something like a Gamma match.
Thanks so much for the clarification.
I guess the camera "fish-eye" effect is making the top length look longer than the middle length. At least I can count the inch marks and see the top length is off-center by 1 inch, having 18 inches to the left and 16 inches to the right. I assume you've caught that by now and adjusted it.
If I remember correctly, it was actually 2" off. The photo was pre-SWR meter testing. I'm surprised you caught that; Even though it was new, I cut the tape a foot in from the front so I didn't have holes in the element. Thanks!
It is important where the 2 cut pieces meet in the middle to be as close as possible. The total length of the two lengths plus the space should probably be 17.5" in order to be ideal according to the software that the original designer was using. I would trim off 1/16" from those pieces to see if it improves. Car anteneas use a spiral groove to add inductance and a metal ball at the top to add capacitance which matches with the characteristics of the surrounding air better. So I bet there's a way to improve upon even yagi designs.
