Introduction: Tape Wallet
This is how to make a wallet that is made out of tape so my young men out there wouldn’t go through the struggle to buy a wallet and waste money, instead one can make a simple wallet that can hold your funds and even credit/ debit cards.
Step 1: Materials
All you need is:
Duct Tape
Clear Packing Tape
Aluminum Foil
Scissors
Duct Tape
Clear Packing Tape
Aluminum Foil
Scissors
Step 2: Duct Tape
Lay down duct tape so that the strips overlap slightly and create a sheet. Make this larger than you will need to the finished pouch to be.
Step 3: Aluminum Foil
Lay the aluminum foil carefully onto your duct tape sheet. The aluminum foil should lay flat for best results.
Step 4: Packing Tape
The final layer of the material is the clear packing tape. This protects the aluminum foil and prevents the metal from touching the chips on credit cards.
Lay the clear packing tape onto the aluminum foil side. Like you did the duct tape, overlap the strips slightly. Cover the entire area that had duct tape on the opposite side.
Step 5: Cut to Size
Trim away the edges to create a rectangle. Then, using a credit-card-sized card, cut the material so that it will be just larger than a credit card when folded in half.
Step 6: Tape Edges
Finally, to close the pouch, duct tape the edges and trim the excess away.
Step 7: Done !
You're done! Put your credit/debit cards in here, and if you’d like put it in your front pockets so it won’t slip out.
Although the one I made worked, please make sure to try out your own pouch before trusting your cards in it !
