Introduction: Taped/Beaded Bookmarks
These beaded bookmarks are a fun and easy way of personalizing your books and don't take much time at all!
Step 1: What You Will Need
You will need:
-As many beads you would like
-Three different kinds of tape if your using tappefitti, or one kind of duct tape if your using that
-Beading string or friendship thread
-1 sheet of card stock paper
-Hole puncher
-Scissors
-Ruler
-Hole puncher
-Scissors
-Ruler
Step 2: Cutting the Paper
I suggest doing 2 inches by 6, but if your using duct tape then you may have to have it bigger. Cut.
Step 3: Finishing the Paper
After that you put your tape onto the paper and then fold over the access tape onto the other side. There should probably be some extra paper on the side, so you can just cut that off.
Step 4: Putting the Beads on and Finishing the Bookmark
Then, punch a hole on the top of the bookmark. After that, you measure 12 inches of your beading string or friendship thread. Put the string inside the hole and then put the two ends together and put all of your beads on. After all of your beads are on you can tie the end about three or four times.
Step 5: Done!
Now you are all done with your bookmark! I hope you enjoyed making this with me!
