Introduction: Tarantula Terrarium
Hello I have 4 pterinochilus murinus and they are around 1 year so I decided to move them to a terrarium, I used wildlife box filled with peat moss,1 water hole and a cave.
The steps with more details I will show you in this instructable.
Step 1: You Will Need a Container and Substrate.
I filled the fauna box with peat moss, but you can use other type of containers and substrates in this case I put enough peat moss so they can dig and makes caves, this tarantulas are semi arboreal and this set-up wil be usefull for terrestrial tarantulas and insects like scorpions or beetles etc.
Step 2: Buy or Do the Drinker
I used common vessels and cut into two to make easier remove them and dont move the ground.
Also I put a rock in that to prevent the drowning.
Step 3: Make the Caves :)
I used a flower pot is cheap and combine with the peat moss.
Step 4: The Background
I find some backgrounds in google and after that I put them in real scale with PS but in the petshops you can find one I try to used something similar to their habitat to make more real and atractive the habitat.
Step 5: Just Install All the Things and the Tarantulas :p
This specie is nervous and fast so I used a long tweezers to manipulate them.
Thats all I hope that you liked this tutorial and if you make one you can share that.
