Introduction: Target Aiming
You need:
- 1 pair of scissors
- 2 different sized circular shapes (pots, bowls, plates, etc.)
- crepe paper
- paint
- stapler
- cardboard/box
- slim piece of cardboard half as long
- short, slim piece of cardboard
Step 1:
First unfold the box, but make sure it stays whole. Next, lay it flat on the floor and position the shapes on the box (see picture). Make sure that the shapes are in the upper third, because you need the lower part as a supporting leg. If you like the distance and position, you can trace the shapes.
Step 2:
You pierce a hole in the middle with your scissors and then cut out the shape. When both circles have been cut out, cover the edges of the circles with crepe paper.
Step 3:
Now turn the cardboard over and attach the long, slim piece of cardboard to the bottom end using the stapler (see picture). Again, make sure that you only staple in the first third.
Step 4:
Now take the short, slim piece of cardboard. This will be used as a holder. In order to determine the correct position of the holder, straighten up the box and look how steep the display should be. Once you have determined the correct position for you, draw the top edge of the flap on the cardboard. This is the position for the lower edge of the holding. You put the piece on and staple it.
Step 5:
Before the display is used, it is decorated in a colourful way. Paint is best suited for this, as it has a low dead weight.
Have fun aiming!!!
