Introduction: Make Tassel Poof Using Credit Card & Shoebox
This is real easy and applicable to not only the tassels I am making for my hats but also for making bows to top wrapped presents.
SUPPLIES
SUPPLIES
- shoebox
- yarn (in this case but also ribbon if you wish)
- card with gaping hole cut out from the middle (old credit card works great)
- scissors (cutting yarn only)]
- Easier to have yarn come from middle of the skein instead from the outside. No mess or the skein rolling all over the place as you pull more yarn from it.
Step 1: Tassel Ends
Image #1
- Place skein in shoebox and have the end come from a hole located on the side of the box. (mine conveniently already had one ^_^ ) So, as you are working with the yarn, it won't matter if the skein is rolling around or not because it is secured within the box the whole time.
- I need to have braid yarn ends coming from the tassel poof. I used the shoe box to wrap the yarn around multiple times and cut in one area to get multiple yarn strands. Used cereal box in the past. Really just depends on how much or little you need.
Step 2: Tassel Poof
- Wrap yarn around the card with a hole multiple times. How many? Depends how poofy you want the poof to be. More = more poofy and less = less.
- Use strand ends from previous step to tie off a very tight knot around the wrapped yarn. See image #3-4
- Cut both ends of the wrapped yarn. See image #5-6
- Braid ends to make tassel with poof or whatever else you need it for.
