Introduction: Temperature-Activated Smart Fan Using DC Motor
This project uses an Arduino Uno to monitor temperature via a TMP36 sensor. When the room temperature reaches or exceeds the set threshold, an LED lights up to signal that it’s too hot. At that point, if a button is pressed, a DC fan powers up gradually, then winds down — providing a manual cooling response based on environmental data.
This system simulates a smart cooling control system — useful in homes, server rooms, or greenhouses where automated, responsive environments are crucial.
  1. Arduino Uno
  2. TMP36 Temperature Sensor
  3. DC Motor (Fan)
  4. TIP120 NPN Transistor
  5. 1N4001 Diode
  6. LED
  7. 200Ω Resistor (for LED)
  8. Pushbutton
  9. 10kΩ Resistor (for button)
  10. 9V Battery + Battery Clip or 9V DC Power Supply
  11. Breadboard + Jumper Wires
Step 1: Build Circuit
Connect the TMP36 Temperature Sensor
  1. Insert the TMP36 sensor onto the breadboard with its flat side facing you.
  2. Left pin → Connect to 5V on the Arduino.
  3. Middle pin → Connect to A0 on the Arduino (analog input).
  4. Right pin → Connect to GND.
Wire the Pushbutton
  1. Place the pushbutton across the central groove of the breadboard.
  2. Connect one side of the button to digital pin 2 on the Arduino.
  3. Connect the same side to GND through a 10kΩ pull-down resistor.
  4. Connect the other side of the button to 5V.
This ensures a stable LOW reading when the button is not pressed.
Connect the Status LED
  1. Place an LED on the breadboard.
  2. Anode (long leg) → Connect to pin 13 on the Arduino through a 200Ω resistor.
  3. Cathode (short leg) → Connect to GND.
Set Up the DC Fan Motor with TIP120 Transistor
  1. Insert the TIP120 NPN transistor onto the breadboard.
  2. TIP120 pinout (flat side facing you):
  3. Left pin = Base
  4. Middle pin = Collector
  5. Right pin = Emitter
  6. Connect one lead of the motor to the 9V battery positive terminal.
  7. Connect the other motor lead to the collector (middle pin) of the TIP120.
TIP120 Control:
  1. Connect the emitter (right pin) of the TIP120 to GND.
  2. Connect the base (left pin) of the TIP120 to digital pin 9 on the Arduino.
Add a Flyback Diode for Motor Protection
  1. Place the 1N4001 diode across the motor terminals.
  2. Stripe (cathode) → Connect to the positive motor lead (battery side).
  3. Non-striped end (anode) → Connect to the TIP120/motor side.
(This protects the transistor from voltage spikes caused by the motor.)
Connect External Power (9V Battery)
  1. Connect the positive terminal of the 9V battery to the motor (already done in Step 4).
  2. Connect the negative terminal of the battery to the Arduino GND (shared ground).
Final Check Before Uploading Code
Make sure:
  1. All GNDs are connected (Arduino, TMP36, TIP120 emitter, button resistor, and LED).
  2. The TMP36 is not reversed (double-check the flat face and pin layout).
  3. The TIP120 is controlling the fan — don’t wire the motor directly to the Arduino.
  4. The 9V battery powers the motor (not the Arduino — unless using a barrel jack).
Step 2: Upload Code + Breakdown
Code:
const int buttonPin = 2; // Button input
const int motorPin = 9; // Fan motor control
const int ledPin = 13; // LED for high temperature
const int tempPin = A0; // TMP36 sensor
void setup() {
pinMode(buttonPin, INPUT);
pinMode(motorPin, OUTPUT);
pinMode(ledPin, OUTPUT);
Serial.begin(9600);
void loop() {
int sensorValue = analogRead(tempPin);
float voltage = sensorValue * (5.0 / 1023.0);
float temperatureC = (voltage - 0.5) * 100;
float temperatureF = (temperatureC * 9.0 / 5.0) + 32;
Serial.print("Temperature (F): ");
Serial.println(temperatureF);
if (temperatureF >= 85.0) {
digitalWrite(ledPin, HIGH);
if (digitalRead(buttonPin) == HIGH) {
for (int speed = 0; speed <= 50; speed++) {
analogWrite(motorPin, speed);
delay(50);
for (int speed = 50; speed >= 0; speed--) {
delay(50);
} else {
digitalWrite(ledPin, LOW);
analogWrite(motorPin, 0);
delay(500);
Section-by-Section Breakdown
Variable Declarations
  1. buttonPin: The pushbutton is connected to digital pin 2.
  2. motorPin: The motor (controlled via a TIP120 transistor) uses pin 9, which supports PWM.
  3. ledPin: The status LED for high temp is connected to pin 13.
  4. tempPin: The TMP36 sensor is connected to analog pin A0.
Setup Function
void setup() {
Serial.begin(9600);
  1. pinMode(): Defines pin roles.
  2. Button as input.
  3. Motor and LED as outputs.
  4. Serial.begin(9600);: Starts serial communication for debugging. You'll see temperature logs in the Serial Monitor.
Main Loop Function
  1. Reads analog voltage from TMP36. Value is between 0 and 1023.
  1. Converts the analog value to actual voltage.
  2. 5.0V is the Arduino reference voltage.
  1. Converts the TMP36 voltage to Celsius.
  2. TMP36 outputs 0.5V at 0°C, and every 0.01V = 1°C.
  1. Converts Celsius to Fahrenheit.
Display Temperature
  1. Prints the temperature to the Serial Monitor for debugging or monitoring.
Check Temperature Condition
  1. If it’s 85°F or hotter, the system gets ready to cool.
  1. Turns on the LED to signal high temperature.
Check Button Press
  1. If the button is pressed, we start the cooling cycle.
Ramp Up the Fan
delay(50);
  1. Increases the PWM signal to the fan gradually.
  2. PWM value from 0 to 50 (out of 255) gives a gentle spin-up.
  3. Each increase pauses for 50ms to create a smooth ramp effect.
Ramp Down the Fan
delay(50);
  1. Slows the fan back down smoothly.
Else Condition (Normal Temp)
} else {
  1. If it’s cooler than 85°F, the system:
  2. Turns off the LED
  3. Keeps the motor off
Loop Delay
delay(500);
  1. Adds a half-second pause before the loop repeats.
  2. Helps smooth sensor readings and reduce noise.
