Introduction: Temperature Controlled AC Home Appliances Using Arduino
The project will assist you to control various home appliances automatically as per temperature.
Hardware Components
Arduino Uno
Relay 5V
NTC Thermistor 10k
16X2 LCD
Potentiometer- 10k ohms
Resistor 1k ohm
Resistor 10k ohm
Software Components
Arduino IDE
Step 1: About Project
This Home Automation System contains various components such as Arduino board, LCD display, Relay and thermistor. The system working completely depends on the relay as well as the thermistor as the temperature raised the relay will be turned on and if the temperature lowered below the threshold value then Relay will be turned off.
The appliance attached to the Relay will also turn on and off respectively. In this system, we have used a CFL bulb as an AC appliance.
Measure Temperature using Thermistor
Calculation of temperature can be done with the help of the following formula
T = 1 / (A + B*ln(Rt) + C*ln (Rt)3 ) where A, B, C are the constants Rt is thermistor resistance
You can take these constant values straight from the datasheet of the Thermistor also.
Relay
Relay basically acts as an electromagnetic switch, which is managed by small current and utilized to switch ON and OFF comparatively much larger current. Means by using small current we can switch ON the relay which enables much larger current to flow.
IoT Course will give you a thorough view of all such IoT Concepts.
Step 2: Run a Program
#include
#include "LiquidCrystal.h"
#define RELAY 8
LiquidCrystal lcd(6,7,5,4,3,2);
float A = 1.009249522e-03, B = 2.378405444e-04, C = 2.019202697e-07;
float T,logRt,Tf,Tc;
float Thermistor(int Vo) {
logRt = log(10000.0*((1024.0/Vo-1)));
T = (1.0 / (A + B*logRt + C*logRt*logRt*logRt)); // We get the temperature value in Kelvin from this Stein-Hart equation
Tc = T - 273.15; // Convert Kelvin to Celcius
Tf = (T * 1.8) + 32.0; // Convert Kelvin to Fahrenheit
return T;
void setup() {
lcd.begin(16,2);
lcd.clear();
pinMode(RELAY, OUTPUT);
void loop() {
lcd.setCursor(0,0);
lcd.print("Temperature:");
lcd.print(int(Thermistor(analogRead(0))));
lcd.print("C ");
delay(500); // wait 0.5 seconds before sampling temperature again
if (Tc > 28) digitalWrite(RELAY, HIGH), lcd.setCursor(0,1),lcd.print("Light status:ON "),delay(500);
else if (Tc < 28) digitalWrite(RELAY, LOW),lcd.setCursor(0,1),lcd.print("Light status:OFF"),delay(500);
