Introduction: Temperature Controlled Fan
For our ME208 Project, our team created a temperature sensor-based working fan. The fan will turn on when the temperature surpasses a certain level and turns off once it's below the certain level (More than 75F in our project). This is helpful for applications such as cooling systems, which allow you to control the temperature of a room or a gadget. The project employs a TMP36 temperature sensor to monitor temperature, a motor drive to drive the fan, and a pushbutton switch to allow the user to manually activate the device.
This article will walk you through the step-by-step process of constructing the components, wiring them together, and uploading the code to the Arduino to make the fan function according to temperature. Whether you're a novice or an experienced Arduino user, this project will teach you how to deal with sensors, transistors, and switches in a fun and useful manner!
- Arduino UNO (1)
- Temperature Sensor (TMP36) (1)
- 5V Fan (1)
- Motor Drive (1)
- Pushbutton Switch (1)
- Breadboard (1)
- Jumper Wires (Multiple)
- Power Supply (5V or USB from Arduino)
Step 1: Set Up the TMP36 Temperature Sensor
- Connect the VCC pin of the TMP36 sensor to the 5V pin on the Arduino.
- Connect the GND pin of the TMP36 sensor to the GND pin on the Arduino.
- Connect the OUT pin of the TMP36 sensor to Analog Pin A2 on the Arduino.
Step 2: Set Up the Pushbutton Switch
- Connect one terminal of the pushbutton to Digital Pin 2 of the Arduino.
- Connect the other terminal of the pushbutton to GND on the Arduino.
- Configure the pushbutton with INPUT_PULLUP mode in the code to activate when the switch is pressed.
Step 3: Set Up the Fan and the Motor Drive
- Connect all the GNDs of the motor drive to GND.
- Connect the positive terminal of the fan to the A01 of the motor drive.
- Connect the negative terminal of the fan to the A02 of the motor drive.
- Connect PWMA to port 11 in the Arduino uno.
- Connect AI1 to 12;
- Connect AI2 to 13;
- Connect STBY to 5V on the breadboard.
Step 4: Upload the Code
Here's our code with comments:
const int tempPin = A2; // Analog pin for thermistor
int MotorOne_AI1 = 12; //Pins for the motor
int MotorOne_AI2 = 13;
int PWMA = 11;
const int switchPin = 2; //Pin for the switch
float tempdata; //variable to store data in
void setup() {
pinMode(MotorOne_AI1, OUTPUT); //Set the pins for the motor as outputs
pinMode(MotorOne_AI2, OUTPUT);
pinMode(PWMA, OUTPUT);
pinMode(switchPin, INPUT_PULLUP); //Set the switch pin as input
Serial.begin(9600); //Let serial monitor start
void loop() {
int switchState = digitalRead(switchPin);
if (switchState == LOW) { // Switch is pressed
tempdata = analogRead(tempPin) * 0.004882813; // Convert to voltage
tempdata = (tempdata - 0.5) * 100.0; // Convert from voltage to Celsius
tempdata = (tempdata * 1.8) + 32; //Convert from Celsius to Fahrenheit
Serial.print("Temp: ");
Serial.print(tempdata);
Serial.println(" F"); //Print in serial monitor
if (tempdata > 75.0) {
turnFanon(255);
// Turn fan ON
} else {
turnFanoff();// Turn fan OFF
} else {
turnFanoff(); // Fan off if switch not pressed
delay(1000); // to stabilize
//Functions for turning fan on and off with the motor drive
void turnFanon(int speed) {
digitalWrite(MotorOne_AI1, HIGH);
digitalWrite(MotorOne_AI2, LOW);
analogWrite(PWMA, speed);
void turnFanoff() {
digitalWrite(MotorOne_AI1, LOW);
analogWrite(PWMA, 0);
Step 5: Testing
Have fun testing the final product!!
Step 6: Instructive Video of Wiring
Link to the video: https://youtu.be/QFkA1zD8WCY
