Introduction: Temperature Measurement Using TMP112 and Arduino Nano
TMP112 High-Accuracy, Low-Power, Digital Temperature Sensor I2C MINI module. The TMP112 is ideal for extended temperature measurement. This device offers an accuracy of ±0.5°C without requiring calibration or external component signal conditioning.
In this tutorial the interfacing of the TMP112 sensor module with arduino nano has been illustrated. To read the temperature values, we have used arduino with an I2c adapter.This I2C adapter makes the connection to the sensor module easy and more reliable.
Step 1: Hardware Required:
Step 2: Hardware Hookup:
The hardware hookup section basically explains the wiring connections required between the sensor and the arduino nano. Ensuring correct connections is the basic necessity while working on any system for the desired output. So, the requisite connections are as follows:
The TMP112 will work over I2C . Here is the example wiring diagram, demonstrating how to wire up each interface of the sensor.
Out-of-the-box, the board is configured for an I2C interface, as such we recommend using this hookup if you’re otherwise agnostic. All you need is four wires!
Only four connections are required Vcc, Gnd, SCL and SDA pins and these are connected with the help of I2C cable.
These connections are demonstrated in the pictures above.
Step 3: Code to Measure Temperature:
Let's start with the Arduino code now.
While using the sensor module with the Arduino, we include Wire.h library. "Wire" library contains the functions which facilitate the i2c communication between the sensor and the Arduino board.
The entire Arduino code is given below for the convenience of the user:
<p>#include<Wire.h></p><p>// TMP112 I2C address is 0x48(72)</p><p>#define Addr 0x48</p><p>void setup() </p><p>{ </p><p>// Initialise I2C communication as MASTER </p><p>Wire.begin(); </p><p>// Initialise serial communication, set baud rate = 9600 </p><p>Serial.begin(9600);</p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Select configuration register </p><p>Wire.write(0x01); </p><p>// Continuous conversion, comparator mode, 12-bit resolution </p><p>Wire.write(0x60); </p><p>Wire.write(0xA0); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>delay(300); </p><p>}
void loop()</p><p>{ </p><p>unsigned data[2]; </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Select data register </p><p>Wire.write(0x00); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>delay(300);</p><p>// Request 2 bytes of data </p><p>Wire.requestFrom(Addr, 2);</p><p>// Read 2 bytes of data </p><p>// temp msb, temp lsb </p><p>if(Wire.available() == 2) </p><p>{ </p><p>data[0] = Wire.read(); </p><p>data[1] = Wire.read(); </p><p>} </p><p>// Convert the data to 12-bits </p><p>int temp = ((data[0] * 256) + data[1]) / 16; </p><p>if(temp > 2048) </p><p>{ </p><p>temp -= 4096; </p><p>} </p><p>float cTemp = temp * 0.0625; </p><p>float fTemp = cTemp * 1.8 + 32; </p><p>// Output data to serial monitor </p><p>Serial.print("Temperature in Celsius: "); </p><p>Serial.print(cTemp); </p><p>Serial.println(" C"); </p><p>Serial.print("Temperature in Farhenheit: "); </p><p>Serial.print(fTemp); </p><p>Serial.println(" F"); </p><p>delay(500); </p><p>}</p>In wire library Wire.write() and Wire.read() is used to write the commands and read the sensor output.
Serial.print() and Serial.println() is used to display the output of the sensor on the serial monitor of the Arduino IDE.
The output of the sensor is shown in the picture above.
Step 4: Applications:
Various applications incorporating TMP112 low power, high accuracy digital temperature sensor include Power-Supply Temperature Monitoring, Computer Peripheral Thermal Protection, Battery Management as well as office machines.
