Introduction: Temperature Sensor for Hot Classroom
This project is designed to create a visual display of temperatures in a hot classroom. It is setup to collect temperatures every 5 seconds (for debugging), but ideally would be changed to every 30 minutes to save battery power.
- Sensor station will collect temperature and convert from C to F. Temp in F will then be sent by radio to the display station.
- Display station will read the temperature from the sensor station and will turn on a light corresponding to the temperature in the room.
- 65-72 = comfortable temperature
- 72-75 = uncomfortable temperature
- 75+ = too hot to learn/work.
- 2 Micro:bits
- Forward Education Micro:Bit Header
- breadboard
- 4-jumper wires
- 3- 220R Resistors
- cardboard stand for sensor
- carboard box for display microbit
Step 1: Design Brief
Design Brief and Pre-Programming Flow Chart
Step 2: Create Sensor Station Code on MakeCode
Use the attached file to see the code for the sensor station.
Step 3: Create Display Station Code on MakeCode
Use the attached file to see the code for the display station.
Step 4: Assemble Display Station: Connect LED's With Breadboard and Connect to Microbits
Assemble LED's with breadboard and connect to micro:bit using Forward Education Header:
Setup Breadboard:
- Connect a ground wire to blue negative rail to the G slot on the header.
- Connect a green LED
- Long leg is plugged into row 3, column j.
- Short leg is plugged into blue negative rail on 4.
- Set up the resistor
- Insert a 220Ω resistor into row 3, column e.
- Insert the other leg into row 3, column g.
- Connect a jumper wire from row 3 to the 0 slot on the header.
- Connect a yellow LED
- long leg is plugged into row 5, column j
- short leg is plugged into blue negative rail on 6.
- Insert one leg of the 220Ω resistor into row 5, column e.
- Insert the other leg into row 5, column g.
- Connect a jumper wire from row 5 to the 1 slot on the header.
- Connect a red LED
- long leg is plugged into row 8, column j
- short leg is plugged into blue negative rail on 9.
- Insert one leg of the 220Ω resistor into row 8, column e.
- Insert the other leg into row 8, column g.
- Connect a jumper wire from row 8 to the 2 slot on the header.
Connect to Forward Education Header:
- Connect the other end of the ground wire into the g slot on the back of the header.
- Connect the other end of the wire in row 3 to the 0 slot on the back of the header.
- Connect the other end of the wire in row 5 to the 1 slot on the back of the header.
- Connect the other end of the wire in row 8 to the 2 slot on the back of the header
Step 5: Design Cardboard Setup for Project
Design cardboard setup for project. Something similar to what is shown in pictures.
Step 6: Test Code
- Download codes to both micro:bits.
- Add battery packs to both.
- If needed, grab an ice pack and hot water to test out temperature sensor micro:bit.
- place micro:bit on ice pack to cool it down.
- hold micro:bit over steam of hot water to heat back up
- When the temperature on the sensor station is between 65F and 72F, the green light should turn on.
- When the temperature on the sensor station is between 72F and 75F, the yellow light should turn on.
- When the temperature on the sensor station is between 75F or higher, the red light should turn on.
- If not working, make sure the breadboard is set up correctly and that the micro:bit code created correctly and downloaded again to both micro:bits as needed.
Step 7: Test Temperature Station in Your Classroom!
- Take your setup to your classroom and let it work!
- LED's should light up as the temperature increases.
- Hope your district decides to do something about the hot temperatures in your room (with no AC).
