Introduction: Temporary Large Scale Portable Restroom
Have you ever been to an outdoor concert, camping festival, or major event and thought, "There has to be a better bathroom solution"?
This project is a large, connected portable porta potty system designed to ride on top of a semi-truck trailer. It provides many private stalls in a compact and mobile package and it is perfect for temporary deployment at large outdoor venues.
This design can help solve long wait lines, improve cleanliness, and offer a much better overall experience for outdoor eventgoers. It's is also built with easy setup and takedown in mind!
In this Instructable, I'll walk you through the basic idea, planning, and construction steps for building this unit.
Plywood or durable plastic panels (walls, floors, doors)
Aluminum framing for lightweight structure
Water tanks (freshwater + greywater)
Plumbing and piping (toilets, venting, water lines)
Portable waste storage tanks (if not using direct connections)
Truck trailer or flatbed platform
Hinges, latches, door handles
Waterproof sealant
Weatherproof paint or coating
Vent fans (optional, battery/solar-powered)
Non-slip flooring material
CAD software (for design tweaks)
Advanced construction tools (Plastic injection molding, CNC machines, metal press machine)
Step 1: Concept and Design
Create a modular design that fits on a standard semi-trailer (~48–53 ft long, 8–8.5 ft wide).
Design individual stalls with walls and doors for privacy.
Include space for freshwater and waste storage if hooking up isn't available.
Create CAD models to refine stall layout, roof slope for rain runoff, and material thickness.
Step 2: Frame Construction
Build the main structure using lightweight aluminum framing.
Weld or bolt a rectangular base frame to match the dimensions of the truck trailer.
Add vertical supports for each stall and roof beams across the top.
Ensure the frame is strong enough to resist flexing during transport.
Focus front of design with aerodynamic frame design
Step 3: Wall and Roof Panels
Cut wall and roof panels from weather-resistant plywood or composite board.
Pre-drill holes and attach panels to the frame with rivets or bolts.
Seal edges with waterproof tape or caulking to prevent leaks.
Paint or coat panels with outdoor-grade waterproof sealant.
Step 4: Doors and Overhang
Weather-resistant materials for each door
Mount doors with stainless steel hinges; add inside slide latches
Extend roof panels 6–12 inches forward to create a protective overhang
Seal all joints to ensure durability during transport and outdoor use
Step 5: Install Plumbing and Fixtures
Install toilet units in each stall (gravity flush, chemical toilets, or vacuum systems).
Run freshwater and greywater lines to tanks or hookup ports.
Install small vent pipes for each stall to reduce odors.
If possible, add solar-powered ventilation fans on the roof.
Step 6: Optional Upgrades
Add solar panels to power ventilation fans or LED stall lights
Install handwashing stations with foot-pump sinks and soap dispensers
Use a fold-out ramp for ADA accessibility compliance
Attach aerodynamic rear panels to reduce drag during highway transport on the semi trailer
Use quick-latch mechanisms for faster assembly and disassembly on-site
