Introduction: Temporary Replacement Cap (Small Nozzle Items)
Have you ever lost a cap? I have. this trick may help you save your capless item.
You will need a capless item
hot glue
hot glue gun
Step 1: Just Apply Some Hot Glue
Your results may vary. Mine have but overall I have been able to save caulking tubes, super glue and craft paints. The smaller and cleaner the tip the better luck I have had.
Just apply enough hot glue to close the tip. It helps to make the blob big enough to grab. If you want to get a little in the tip, gently squeeze the bottle and apply the glue. Once you relax the bottle it will draw the glue in a little bit. Be careful if you do this as you may cause more problems than you solve.
There's not much to this one. If you have a cap this is not meant to replace caps, but if you are in a tight spot with out a cap, give this a shot.
