Introduction: Temporary Surfboard Nose Repair
My surfboard got a ding in the nose and it got to the point where it was sharp and a safety hazard. So, I wanted to fix it. Unfortunately I didn't have the right materials, so I decided that I'll just give it a temporary fix. I got the ding when my surfboard got dropped (which I don't recommend trying) from a height. It hit at just the right angle so it flattened the tip of the nose making it razor sharp (it actually scraped me a couple times). In this tutorial you could use this idea to fashion a surfboard nose guard too.
Step 1: Materials
You are going to need a surfboard (mine had a ding), and silicone.
Step 2: Making the Gaurd
Now just add a glob of silicone all around the nose. You then want to flatten it out and shape it.You can use a tool, for example, I used a popsicle stick, or even better, get your finger wet and the silicone won't stick to it so you can use your finger. I made it as flush with the board as possible so it would look nice and not affect the board at all. That's it!
Note: This was more an idea, because anyone can figure this out. It's more of an idea on how to cheaply fix a problem with your surfboard.
Also it makes it a lot easier if you have a surfboard shaping rack which I show you how to build here.
Glue Contest
Summer #mikehacks Contest
2 Discussions
6 years ago on Introduction
Never knew the trick about wetting your finger to keep the silicone from sticking. Nice fix!
Reply 6 years ago on Introduction
Thank You. It helps to have friends that work a lot with silicone.
