Introduction: Tempreture | Humidity | Node Mcu | DHT11
hello guys today in this tutorial we are going to interface the dht11 tempreture and humidity sensor with nonde mcu and get the readings
if you guys havent had the NODE MCU setup done into yur arduino software then here is the link you must follow for setting up your node mcu first
https://www.instructables.com/id/Quick-Start-to-No...
Step 1: Components Required
NOde mcu
dht11
jumper wires
bread board
Step 2: Installing Library
you got to install the ibary first if its not there
you can simply google search it out
"arduino llibrary for dht11"
Step 3: Connections
Step 4: C O D E
downlaod this code and then opne this in to your software and upload it and
dont forget to change the baud rate to 115200 from 9600
