Introduction: Tennis Ball Stamp
Today I will show you how to make a tennis ball stamp for tennis balls. You can add custom names or sayings.
A 3d printer
3d design site (Tinker Cad is the easiest for this)
Tennis Balls
Paint (Any color)
Step 1: Go to Your Site
Go to Tinker Cad
Step 2: Find Curve Text
Find curved text
Step 3: Apply Settings
Apply these settings and add your text in where it say "Your text here"
Step 4: Turn Your Model
Turn the text so its facing parallel with the front side of the base plate
Step 5: Make a Circle
Make a circle (My circle is 3.5 by 3.5)
Step 6: Fit Circle
Fit circle around the text (you can always make the text thickness to be bigger)
Step 7: Trim
Trim your circle as close to the letters as possible
Step 8: Add Handle
Add a handle (My handle was 2.5 inches long and 0.5 inches wide
Step 9: Done
Done (Make sure to print with supports on)
Step 10: How to Use...
Apply paint to the letters
Put the ball on a flat surface with the stamp side up
Pull the edges apart with little pressure while moving the stamp (Down) towards the ball
Apply pressure to the stamp on all sides once the stamp is fully touching the ball
Wait 20 to 30 seconds
Pull the edges apart with little pressure while moving the stamp (Up) away from the ball
Let the ball dry for 5 to 10 mins
Done
