Introduction: Tensegrity Sculpture
In this instructable I will you show to make a tensegrity structure.
Cardboard
Hot glue gun
Hot glue
String
Scissors
Pencil
Ruler
Sharpie
Step 1: Draw Out the Pieces
The first step is to draw all of the pieces needed on the piece of cardboard.
Step 2: Cutting the Pieces Out
Second step is to cut along the lines you drew earlier.
Step 3: Hot Glueing
Third step is to hot glue the pieces together. The pieces are grouped together the way they should be glued together. On the top piece and base I drew a square where the L pieces should be glued on.
Step 4: Glueing on the Strings
You need to cut two pieces of six inches of string and two pieces of two inch strings. The long pieces are glued on the top and base in the corners. The short pieces of string are glued to the short parts of the L shaped parts.
