Introduction: Tensegrity Tetrahedral Tower
There are a few 'Tensegrity Tables' on the internet. They mainly appear to be made of two 'J' members with the top one upside down. They are interesting and intriguing but not the only compression members which can be used to make a tensegry structure. In this instructable I will be using Tetrahedrals.
The Tetrahedral is made of 4 equilateral triangles. This also give it structural rigidity.
Each of the tetrahedrals are suspended independently, meaning they don't touch each other, only being connected by nylon fishing line.
Step 1: Make the Members
Partially blow up 4 balloons so they are round but not too bigs, these will be used as connection point for the tubes.
Make Cross members by rolling up some cardboard into 6 tubes.
Attach a tube end to a balloon with tape.
Step 2: Make a Triangle
Make a triangle by joining together 3 balloons and tubes with tape.
Step 3: Make a Tetrahedral
Make a tetrahedral by joining 3 more tubes and a balloon to the triangle.
Step 4: Positioning of Tetrahedrals
Make two more tetrahedrals but in these hold off finishing connecting one of the tube ends to a ball on. This is so it can fit into the center of the first tetahedral so the 3 are linked.
Connect through the 1st tetrahedral and secure to the last tube ends to their balloons to complete the tetrahedrals, now linked together.
Step 5: Tower Build
After the tetrahedrals have been built linked together. Use nylon fishing line to suspend the upper tetrahedral from the lower one so they form a tower.
Then connect the side balloons together with fishing line and tape so the tower becomes stable.
