Introduction: Tension Table
this was a design that came to me and smacked me in the face so i ran with it and this is what i came up with...
the table top is supported by a central pole.
the string evens out the load on the table top.
the higher the tension the more rigid the table...
provided the central pole can support the tension.
Step 1: Materials ( Not Shown)
i made the table before i thought about making an instructable to go with it.
plywood
2 inch wood screws
para cord (or other strong string, or cable)
17x eye screws
1 inch pvc pipe
old satalite dish( if you dont have one of these just use some plywood)
small table top(also can be substituted with plywood)
TOOLS
drill
jig saw
circular saw
hole saw
plywood
2 inch wood screws
17x eye screws
1 inch pvc pipe
TOOLS
drill
jig saw
circular saw
hole saw
Step 2: Drill Holes
measure the center of your table top and drill a hole with your 1 inch hole saw
and insert your pipe...
must be a tight fit or your table will be wobbly.
Step 3: Attach Plywood to Dish
you can skip this step if you are just using a piece of plywood as your base.
just drill a hole 3/4 of the way through your wood and insert the pipe into it.
to keep the plywood and the pvc pipe in place i just used a single large bolt and placed the pipe over it.
Step 4: Attach Eye Screws
place eye screws at the corners and the midpoint on the sides.
(illustrated below)
(illustrated below)
Step 5: String the Eyescrews
string the screws like so...
tie it of like in the second picture
Step 6: Adding Tension
hold the table top level and begin adding tension to the string evenly around the table.
pluck the strings all the way around and if you hear the same high note throughout all of the strings you've done it right.
Step 7: Enjoy
do as the step title says!!!!!!!!!!!!!!!
