Introduction: Tesla Coil Using Pcb
This is an awesome PCB project using simple electronic components . It is simple project you just need to design your PCB , order it and a bit of soldering practice to make this project.
This project works on the concept of wireless electricity you can generate electricity to run simple things like bulbs and led.Hope you guys will enjoy it...............
So let's get started.
We need-
PCB
Coil(350T,3T)
2k resistor
LED
Capacitor(1uf,0.1uf)
IRF530 mosfet
TIP41 transistor
Heatsink
Sockets(DC,AUDIO)
Step 1: Designing the Pcb
By the first we have to design the PCB according to our need. So on the bases of our components i have designed a PCB using Easy EDA software. Its a very great software to design PCB and schematics just for free.To make this PCB firstly we have to make the schematic ,save it and then further convert it to PCB.
If you too want the schematic and PCB here , i am providing the schematic and you just need to open it in Easy EDA and convert it to PCB Gerber .
Step 2: Ordering the PCB
To order the PCB i used one of the trusted sites for pcb manufacturing. That is JLCpcb.com
If you are new to the site just order the pcb now bcz u are getting free coupons too.
You can get the pcb delivered within 15 days too.
Step 3: Finally PCB's in Hand
I received the pcbs and we are now going to start assembling.
Step 4: Soldering in Progress
So guys it took me a bit long to solder because the components were way tricky to solder than i thought.
So when i was doing soldering i noticed a problem that i want to share with you guys that whenever you are soldering and you get bridges in it they must be removed or else.... you end up having trouble to solder perfectly you must keep a desoldering pump handy too. By the way when i had all my work done in soldering it looked spectacular.
Step 5: Finishing Once ....Looks Cool...........
Once you are done with the soldering work you have to cut out those extra wires. And be a lot lot careful while connecting the coil terminals too.
Step 6: Functioning .........amazing
So once you are done. Your coil starts conducting electricity wirelessly and you have a hand made tesla coil too.
This gives you a bit of exp. and handiness in soldering and pcb. Hope you like it and if you did then dont forget to vote.
Thank you , goodbye.🧡😊
