Introduction: Texting Mat
Please enjoy the video:
https://vimeo.com/81472818
Step 1: Text-Mat
Lusha and May created a "Text-Mat”. This surface can allow the user to write and send messages using one’s feet. This text-mat is designed to send secret messages during meetings or classes. The design utilizes conductive fabric and thread, as well as a flora-board. The program contains 7 preset sentences. The user can press a button to select the appropriate sentence and then a final button to send.
Step 2:
Next, we cut the wool, felt and conductive fabrics to the desired sizes.
Step 3:
3. We then used the sewing machine to sew the fabrics together.
Step 4:
. 4. Next, we sewed the conductive thread to make a circuit with the conductive fabric.
Step 5:
5. Then we ironed the edges flat.
Step 6:
6. Then we connected the flora board into the circuit.
Step 7:
7. We prepared the following code for the flora: _________
Step 8:
8. We then connected the smart phone and Arduino with the USB connection.
Step 9: Code
The code:
#include
CapPin cPin_10 = CapPin(10); // read pin 10 (D10 on Flora) - connect to NES B
CapPin cPin_9 = CapPin(9); // read pin 9 (D9 on Flora) - connect to NES A
CapPin cPin_6 = CapPin(6); // read pin 6 (D6 on Flora) - connect to NES Start
CapPin cPin_12 = CapPin(12); // read pin 12 (D12 on Flora) - connect to NES Select
CapPin cPin_1 = CapPin(1); // read pin 1 (TX on Flora) - connect to NES right
CapPin cPin_0 = CapPin(0); // read pin 0 (RX on Flora) - connect to NES up
CapPin cPin_2 = CapPin(2); // read pin 2 (SDA on Flora) - connect to NES left
CapPin cPin_3 = CapPin(3); // read pin 3 (SCL on Flora) - connect to NES down
CapPin pins[] = {cPin_10, cPin_9, cPin_6, cPin_12, cPin_1, cPin_0, cPin_2, cPin_3};
// check http://arduino.cc/en/Reference/KeyboardModifiers for more info on unique keys
// WASD D-pad, select = Return, start = Space, LeftButton = z, RightButton = x
//char Keys[] = { 'x', 'z', ' ', KEY_RETURN, 'd', 'w', 'a', 's'};
// arrow D-pad, select = Return, start = Space, LeftButton = b, RightButton = a
//char Keys[] = { 'a', 'b', ' ', KEY_RETURN, KEY_RIGHT_ARROW, KEY_UP_ARROW, KEY_LEFT_ARROW, KEY_DOWN_ARROW};
char* Keys[] = {"hello", "winkyface", "you there?", "hi", "I'm bored", "let's meet for lunch", "zzz", "bye"};
boolean currentPressed[] = {false, false, false, false, false, false, false, false};
// Capactive touch threashhold, you might want to mess with this if you find its too
// sensitive or not sensitive enough
#define THRESH 500
float smoothed[8] = {0,0,0,0,0,0,0,0};
void setup()
//while (!Serial)
Serial.begin(115200);
Serial.println("start");
Keyboard.begin();
void loop()
for (int i=0;i<8;i++) {
delay(1);
long total1 = 0;
long start = millis();
long total = pins[i].readPin(2000);
// check if we are sensing that a finger is touching the pad
// and that it wasnt already pressed
if ((total > THRESH) && (! currentPressed[i])) {
Serial.print("Key pressed #"); Serial.print(i);
Serial.print(" ("); Serial.print(Keys[i]); Serial.println(")");
currentPressed[i] = true;
Keyboard.println(Keys[i]); //sends string as keyboard presses, ending with the ENTER key
else if ((total <= THRESH) && (currentPressed[i])) {
// key was released (no touch, and it was pressed before)
Serial.print("Key released #"); Serial.print(i);
currentPressed[i] = false;
Keyboard.releaseAll();
// simple lowpass filter to take out some of the jitter
// change parameter (0 is min, .99 is max) or eliminate to suit
smoothed[i] = smooth(total, .8, smoothed[i]);
Serial.print(i); Serial.print(": ");
Serial.print( millis() - start); // time to execute in mS
Serial.print("ms \t");
Serial.print(total); // raw total
Serial.print("\t->\t");
Serial.println((int) smoothed[i]); // smoothed
delay(5);
// requires recycling the output in the "smoothedVal" param
int smooth(int data, float filterVal, float smoothedVal){
if (filterVal > 1){ // check to make sure param's are within range
filterVal = .999999;
else if (filterVal <= 0){
filterVal = 0;
smoothedVal = (data * (1 - filterVal)) + (smoothedVal * filterVal);
return (int)smoothedVal;
#include
#define THRESH 500
void setup()
//while (!Serial)
Keyboard.begin();
void loop()
delay(1);
long total1 = 0;
delay(5);
filterVal = 0;
