Introduction: ThaBrain – an AI-Powered Serial + MQTT Interface for Smart Robotics and Automation
ThaBrain is an intelligent desktop application designed to control and monitor smart devices via Serial and MQTT communication. What sets it apart? It comes equipped with an integrated AI assistant (OpenAI) that can interpret responses, give feedback, and even generate commands using natural language.
Whether you're building robots, smart automation systems, or IoT gadgets — ThaBrain gives you an intuitive GUI, logging tools, encryption support, and complete control.
📦 Features
- ✅ Serial + MQTT real-time communication
- ✅ Web-based GUI (Dash/Flask)
- ✅ Command repeat, auto-scroll, and logging
- ✅ Integrated OpenAI assistant
- ✅ Memory file for behavior tracking
- ✅ Multilingual support
- ✅ .exe installer available
- A Windows PC (or Linux with Python 3.11+)
- Arduino, ESP32, or any Serial/MQTT-enabled device.
- Internet connection (for AI assistant and updates).
- Optional: Sensors, actuators, wireless modules.
Step 1: 💻 Step 1: Install the Software
Option A – Use the Prebuilt Installer
- Go to the https://github.com/Arduino4AllJP-AI/ThaBrain/releases/tag/OpenAI
- Download Tha_Brain_Installer.exe.
- Run as administrator.
- Launch ThaBrain from your Desktop.
- Apply yout API KEY
- Close and re-open the software
Step 2: 🧠 Step 2: Train Your Devices
On the isntallation folder, modify your memory.txt file withall the specs of your device
Example:
"Device1 has a servo conected to it, to move the servo on Device1, the command is: Device1/servocommand/position/255"
Step 3: Final Thoughts
ThaBrain is ideal for students, developers, or hobbyists working on automation, robotics, or smart devices. By merging real-time communication with AI, it gives you superpowers in the world of embedded systems.
✨ Example Use Cases
- Controlling a servo from your phone using MQTT
- Monitoring ESP32 sensor data with real-time decoding
- Having ChatGPT help you debug serial messages
- Managing Modbus/LoRaWAN interfaces for industrial IoT
