Introduction: The 1st TRULEY Aerodynamic Paper Airplane
Every one knows that paper airplanes would not fly if it weren't for lift. So one day while looking through a book of paper airplanes I saw a "twirly bird" you know those little helicopters that are just a crude propeller and a stick down the middle that you rub between your palms so it will fly? And it said to fold a piece of paper in half with a straw in the center, and then to glue the other side shut. This creates a very good airfoil for no trouble at all, and so I thought- Why not use that in a paper air plane? After a series of tests this is what worked best for me, but performance can vary big time with a few errors (don't worry though, I have plenty of fixes you can try).
BTW: I ran the math and this thing has an average 6 to 1 glide ratio, but my best is around 19 to 1
SUPPLIES:
printer paper x1
your run-of-the-mill bendy straw x1
This takes five minutes so please try it out!
The videos are the final product
SUPPLIES:
printer paper x1
Step 1: THE SUPER EASY STEP!
My paper airplane is what most people call the "classic" paper airplane (long, slender, delta wings) so check the picture and if you know how to make it (and you probably do) go ahead and skip to step two.
If you don't know how to make it, just follow the pictures:
VIDEO #2
VIDEO #2
Step 2: Making the SUPER AIRFOIL (takes Like a Minute)
This is very easy- insert your straw into the edge of the a wing and make sure that it goes the length of the WHOLE WING, you might hit a piece of paper trying to push it in, and if you do just open up the wing and thread the straw above the obstacle.
Then make sure the straw is up against the edge of the wing and crease the wing along the INNER side of the straw (the side closest to the center to your center-fold)
Remove the straw
You should see a little bump a bit less than a centimeter in width running the length of your wing, if you do do the same to the other side, if you don't check the pictures and makes sure you understand the instructions
You should now have a wired looking paper airplane, toss it VERY gently and watch it's smooooooth, sloooooooooow decent
Or it could have spiraled out of controll, if it did (and it probably did) go to the next step.
VIDEO #3
Remove the straw
VIDEO #3
Step 3: Tweaks, Tips, and Tricks
Alright, this is a very temperamental design, and so I ask you to try as many of these as necessary, and welcome you to try your own.
Vertical stabilizers (tail fins):
Fold the edges of the wings of the plane in by about a 3/4 inch
***HAS BEEN REQUIRED ON ALL MY AIRPLANES OF THIS DESIGN****
Rudder:
cut along the fold of the vertical stabilizer about 1/2 inch to allow you to fold it left or right
Elvons (aileron / elevator combo):
The most important thing to know is that this can ruin a potentially very good paper airplane, and should be used as a last resort. Along the rear of the paper air plane make two 1/3 inch cuts that are 1 inch apart into the wing, do this on each side the same distance from fuselage to wing edge on both wings. Fold up, down, either side with any combination.
*do not make your folds for the elvons very intense, a little fold will go a long way
Hard Toss Design:
Now as you look at you plane you will notice a gap between the two layers of the wing that runs not too far off parallel to the wing edge, tape that down. WaLa! The plane is now balanced, and has more mass giving it greater momentum and tolerance to wind/ high speeds
*******THIS MUST BE DONE AFTER THE NOSE GETS BENT*********
Rudder:
Hard Toss Design:
