Introduction: The Accidental Coke Slushy And/or Explosion
One day I was just going around my fridge when I found this coke bottle lying in the freezer. I took it out, it was completely frozen, and I got and idea for some coke slushy. I did something to it. I opened it. Then, it exploded on my face. So, here I am with this instructable.
Notice: There could be some details left out, but if you do it right you should be fine. Please inform me if something goes wrong.
Please rate and comment!
Step 1: Get What You Need
Here's what you need:
-Coke still packaged in a bottle
-Freezer
-Spare time since it takes a while
Make sure the coke you're going to get is in a bottle and not a can. I'll explain this later on.
-Freezer
Step 2: Put the Coke in the Freezer and Let Freeze
Now here's what's important about having the coke in a bottle. As I was surfing the internet looking for the appropriate images I came across a certain image that fit the warning label. You must partially empty the bottle in order to not get a mess in your freezer. Why not partially empty a can? Well, you'l lose the fizz that makes coke a good drink due to the whole on the top when you pop it open. You could put the contents in a larger container, but it's easier to just get a bottle. Why would it mess up? Water expands as it freezes, and coke uses a lot of water. Since it's almost impossible to compress, the water will exert force on the walls of the container and destroy it. If it's partially empty the coke will have more room to move around.
In short get a bottle, and partially empty it. Then, shove it into the freezer. Make sure it's completely frozen when you take it out, or you'll fail.
Step 3: Processing the Coke Into a Slushy
Take the bottle out, and quickly shake it to break down the solid parts of the coke to a slurry and to release carbon dioxide. Be careful about shaking the bottle for too long. You might lose the fizz for the slushy, as I have observed on mine. Also, worry about releasing too much CO2 and pre-exploding the bottle.
Step 4: Cautiously Opening the Bottle and Boobytrapping
This is where common sense kicks in. You need a strong grip if you only want the explosion, and no rogue cap flying around hitting some random person on the head. If you don't have a strong grip, simply point bottle away from fragile things and people and open. You may hear a really loud pop as a result. Several times I lost the cap of some soft drinks because of the unexpected, at the time, explosion.
Just in case, wear safety goggles, and protect all valuables from a possible rogue cap.
You could also make someone afraid of soda bottles by setting that person up with a booby trap. First, get a coke bottle, and shake it vigorously. Place it in the fridge as if it was already sitting there since forever. When he/she comes by offer that person a drink. Pull out the coke bottle and give it, but excuse yourself because you have to get something and point out where the cups are. Tell him/her to keep their face away from the bottle as it has a tendency to "erupt" in a soda fountain. This will ensure that their face will remain intact during ambush time. Run away, normally, and wait for the scream that comes after the shock wave! Actually, there are two ways it can happen. One, you get a regular soda fountain. Two, you get the explosion. What you want is the explosion. I have also found that smaller bottle tend to explode more often when you shake them for a really long time, and there is only a few inches of air inside. Experiment on the ratios and ambush your prey!
Comment if you have any questions whatsoever.
