Introduction: DIY Altoids USB Apple/Samsung Charger
If you read my profile description, I say that I LOVE to build USB devices. I always am thinking of devices to charge next with that apple-like feature that tries to stop us DIY-ists to build our own chargers. You obviously know that Apple puts that into their devices (iOS 7 does not have that feature, haha! They forgot it :-D). Well, we always find a way to trick those devices into believing what they are suckling energy from is a $20 wall charger. In reality, it is a portable pocket charger, from our minds of the electronic world. I always like to use the nice, perfectly-sized Altoids! In various sizes, you can find the perfect sized one.
I used the regular sized tin, the one found at every grocery store. There is enough room for the battery, the boards, switches, LEDs, USB, and wires. This project will take some time, I split it up in days, one day you cut the holes in the tin, another you solder the main boards, the next you hot glue, etc. Clumped all together, if you are a beginner, it may take 2-3 hours. All together for me, it took about 2 hours total. Happy Tinkering!
~changingelectronics
Step 1: Gather All of Your Parts!
9V battery clip- 1
9V battery- 1
on-off-on toggle switch- 2
22uF capacitor- 1
7805 5V regulator (If you have any better ideas than this, use it.)- 1
10nF capacitor- 1
33k resistor- 4
22k resistor- 2
10k resistor- 2
female USB- 1
perf board
LED (any color)- 1
350 ohm resistor- 1
Altoids tin (or really any casing)- 1
Tools
Soldering Iron
Solder
Hot Glue Gun
Wire strippers
Electrical Tape
*BEFORE ANYTHING- Wrap some electrical or duct tape around the USB. Cut it off so that it will fit around the outside of the USB. Don't cover up the pins. This is so we can hot glue the USB so that we can easily plug it in and out easily. The tape will not allow any hot glue in the USB.
Step 2: Lets Make the Main Board.
First, grab your 22uF capacitor. put it first on the perf board and solder it on. Bend the legs apart and trim off the legs. Now, take the voltage regulator. If you do not know the pin out, google an image of one. Search "Voltage regulator pin out"... The middle leg is ground, and you must solder the ground on. To connect the volt. regulator to the capacitor, drag solder across the perf board. The left V.R. pin is the input, so solder the + of the cap. there. The right pin is the 5V output. Try not to trim the V.R. legs. Now, solder your 10nF capacitor after the V.R. The way my 10nF capacitor was made, you can solder either leg to the + or - input. This is the main board. We will deal with the voltage dividers later.
Step 3: Before the Main Board.....
We must solder our toggle switch.
Mine is an on-off-on, meaning when the pole is in the center, it is off. When you flip it to either side, it turns on, so you can make a 2-in-1 project. So, it can have an iPod charger in one part, and a fume extractor in another. Well, you can use that kind, or a regular on-off switch. Solder the + input to the switch. The - can go right ahead to the board. Once the battery clip is hooked up to the switch, then grab a wire and solder it to the switch. Hook the other end of the wire to the + end of the board.
Step 4: After the Main Board...
Step 5: The USB
Step 6: Enjoy!
Have questions? put them in any section, and I will check!
Have ideas that I should make? Put them in the intro comments!
