The Arduino Piano
Intro: The Arduino Piano
This "Piano" is able to play an octave of a real piano. The pressing of buttons will represent the pressing of a key on the piano. The sound will be relayed through a Piezo speaker.
STEP 1: Materials
1. Arduino Uno
2. USB wire
3. 3 breadboards
4. 8 Pushbuttons
5. 8 100 Ohm resistors
6. "Piezo" Speaker
7. Many Male Wires (About 20)
8. Soldering Iron
STEP 2: Build the Setup
Build 8 buttons with each going into 8 different pins in the Arduino, adding a resistor to each, and connecting them to ground (using the Male wires).
Connect the speaker to the designated Arduino pin, and the other side to ground. You will have to solder the wires to the speaker so it doesn't fall off. Make sure the two wires that are soldered to the speaker do not touch each other.
STEP 3: Constructing the Code
#define NOTE_B0 31
#define NOTE_C1 33 #define NOTE_CS1 35 #define NOTE_D1 37 #define NOTE_DS1 39 #define NOTE_E1 41 #define NOTE_F1 44 #define NOTE_FS1 46 #define NOTE_G1 49 #define NOTE_GS1 52 #define NOTE_A1 55 #define NOTE_AS1 58 #define NOTE_B1 62 #define NOTE_C2 65 #define NOTE_CS2 69 #define NOTE_D2 73 #define NOTE_DS2 78 #define NOTE_E2 82 #define NOTE_F2 87 #define NOTE_FS2 93 #define NOTE_G2 98 #define NOTE_GS2 104 #define NOTE_A2 110 #define NOTE_AS2 117 #define NOTE_B2 123 #define NOTE_C3 131 #define NOTE_CS3 139 #define NOTE_D3 147 #define NOTE_DS3 156 #define NOTE_E3 165 #define NOTE_F3 175 #define NOTE_FS3 185 #define NOTE_G3 196 #define NOTE_GS3 208 #define NOTE_A3 220 #define NOTE_AS3 233 #define NOTE_B3 247 #define NOTE_C4 262 #define NOTE_CS4 277 #define NOTE_D4 294 #define NOTE_DS4 311 #define NOTE_E4 330 #define NOTE_F4 349 #define NOTE_FS4 370 #define NOTE_G4 392 #define NOTE_GS4 415 #define NOTE_A4 440 #define NOTE_AS4 466 #define NOTE_B4 494 #define NOTE_C5 523 #define NOTE_CS5 554 #define NOTE_D5 587 #define NOTE_DS5 622 #define NOTE_E5 659 #define NOTE_F5 698 #define NOTE_FS5 740 #define NOTE_G5 784 #define NOTE_GS5 831 #define NOTE_A5 880 #define NOTE_AS5 932 #define NOTE_B5 988 #define NOTE_C6 1047 #define NOTE_CS6 1109 #define NOTE_D6 1175 #define NOTE_DS6 1245 #define NOTE_E6 1319 #define NOTE_F6 1397 #define NOTE_FS6 1480 #define NOTE_G6 1568 #define NOTE_GS6 1661 #define NOTE_A6 1760 #define NOTE_AS6 1865 #define NOTE_B6 1976 #define NOTE_C7 2093 #define NOTE_CS7 2217 #define NOTE_D7 2349 #define NOTE_DS7 2489 #define NOTE_E7 2637 #define NOTE_F7 2794 #define NOTE_FS7 2960 #define NOTE_G7 3136 #define NOTE_GS7 3322 #define NOTE_A7 3520 #define NOTE_AS7 3729 #define NOTE_B7 3951 #define NOTE_C8 4186 #define NOTE_CS8 4435 #define NOTE_D8 4699 #define NOTE_DS8 4978
These "#defines" are to tell the speaker which frequency makes which note
const int C = 2; const int D = 3; const int E= 4; const int F = 5; const int G = 6; const int A = 7; const int B = 8; const int C2 = 9; const int piezoPin = 10; int cState = 0; int dState = 0; int eState = 0; int fState = 0; int gState = 0; int aState= 0; int bState= 0; int c2State= 0;
Designate the Arduino pins to the buttons. "cState, dState, eState, etc;" are variables that save whether the button is pressed. A 0 means it is not pressed, a 1 means it is pressed.
void setup() { // put your setup code here, to run once: pinMode(10, OUTPUT); Serial.begin(9600); }
void loop() { // put your main code here, to run repeatedly: cState = digitalRead(C); dState = digitalRead(D); eState = digitalRead(E); fState = digitalRead(F); gState = digitalRead(G); aState= digitalRead(A); bState= digitalRead(B); c2State= digitalRead(C2);
The state of the button (if it is pressed or not) is saved in "cState, dState, eState, etc;"
if(cState ==1){ tone(piezoPin, 131); }else{noTone(piezoPin);} if(dState ==1){ tone(piezoPin, 147); }else{noTone(piezoPin);} if(eState ==1){ tone(piezoPin, 165); }else{noTone(piezoPin);} if(fState ==1){ tone(piezoPin, 175); }else{noTone(piezoPin);} if(gState ==1){ tone(piezoPin, 196); }else{noTone(piezoPin);} if(aState ==1){ tone(piezoPin, 220); }else{noTone(piezoPin);} if(bState ==1){ tone(piezoPin, 247); }else{noTone(piezoPin);} if(c2State ==1){ tone(piezoPin, 262); }else{noTone(piezoPin);} }
If a button is pressed, it tells the servo to play the certiain frequency (note). The function
{noTone(piezoPin);} tells them that if the button is not pressed to play nothing. Therefore whenever the button is pressed, it will play its designated note.
2 Comments
tliguori330 6 years ago
I will have to try this out some time
Swansong 6 years ago
That would be fun to play :)
