Introduction: The Atari Stool
It's been a while since I've had the chance to sit down and contribute to this community. I've been meaning to share my plywood Atari chair for some time now because it's one of the most successful projects that I have completed in my woodworking class. Somehow when I sat down to design a stool to make for my class, I had a vision of the Atari logo. That vision turned into the ATARI stool. A must have for someone like me that grew up playing Asteroids, Battle Tank and Plaque Attack. Oh, and don't forget OINK. E.T. can stay buried in the desert.
Anyway, the kids absolutely loved making the stool, and the results were amazing.
Step 1: Planning
For a project like this, it's essential that you plan out the pieces carefully. Because this was a group project, I took the time to make jigs that would help us make each piece accurately. My initial prototypes made me realize that the best material for a design of this type would be baltic birch plywood. It's structurally quite strong and the unfinished edge of the plywood itself still has some curb appeal.
As always, I modeled the stool in RHINO 3d. The leg design went through several variations until I got it just right. I was also able to make a decent flush trimming jig to help make the process safer. I'm still in the process of trying to figure out the best way to guard the flush trimming process. New regulations have been put in place in our board, and using a jig like this will need some approval in the future.
Step 2: Building the Legs
The legs are simple to make with the flush trim jig. Two legs can be cut out of one piece of plywood. Please follow the plans provided for the measurements.
- plywood is cut to 21-1/2" x 7-1/2"
- leg template is traced on either side of the piece
- notches can be cut on a dado saw for accuracy, or band saw if you don't have the proper setup
- length of legs should be cut on the miter saw using a stop block to ensure accuracy
- legs are then rough cut on the bandsaw (try to get as close to the line, less work for the router bit)
- legs are then flush trimmed on the router table
Step 3: Building the Seat
This is the easy part. We used 2" poplar to make the seats. You could also use laminated plywood to get the thickness required. Again, please follow the provide plans for this part.
- cut two blocks of wood to glue up for the seat
- trace the circle on the top of the finished piece, and then cut out on bandsaw
- top edge of the seat should be routered for comfort
- a 1" diameter hole should be drilled to a depth of 1-1/2" in the underside of the stool to accept the post
- it's optional, but a CNC design cut into the top of the chair is cool
Step 4: Turning the Threads
Turning the threads is pretty cool, but it requires a little bit of setup and fine tuning. The kits can be found from a few different places. I found it at Lee Valley in Canada. It's a little pricey, but it's the best way to cut threads in wooden dowel. I've tried the other methods and I don't even want to talk about it.
Step 5: Assembly
Assembly is pretty straight forward.
- First we attached the leg pieces using our trusty pocket-hole jig and some wood glue. This works pretty good, but you have to be careful with the placement of your screws when using plywood
- On some of the stools we employed a wedge joint for the top of the seat post. This works pretty good, but you have to be precise or you can split the dowel. If you manage to get a nice tight fit, would glue will be sufficient. The seat flange piece also helps to make the seat fairly rigid.
- it's really important to center the holes in all of the other seat pieces so that the post can turn freely. A few of my students had these measurements wrong and found it hard to spin the seat. Waxing the threads helps immensely!
Step 6: The Finished Product.
As you can see, there were a lot of great results!!
Please forward any questions that you have. This instructable is not as thorough as I would usually make it. I just haven't had the time!! I will upload a few short videos of the some of the kids at work soon. ENJOY!!
