The Breakdown on Cleaning a Break-Action Shotgun
Intro: The Breakdown on Cleaning a Break-Action Shotgun
If you own a shotgun, or any other firearm, it is important to keep it clean. A dirty firearm could result in injury or even death. In this intructable I will demonstrate how to clean a break-action shotgun.
Warning: Cleaning a firearm can be very dangerous. Before cleaning your break-action shotgun, make sure it is unloaded. This is easy to do with a break-action shotgun because break-action shotguns are loaded one shell at a time at the breech (the back end of the barrel) you simply need to look down the breech to see if there is a shell in there. Once you have made sure your gun is unloaded you are ready to start cleaning. Remember to always keep the muzzle (the front end of the barrel) pointed in a safe direction, either towards the sky or towards the ground.
STEP 1: Obtain a Shotgun Cleaning Kit
The first thing you need to do is obtain a cleaning kit. Kits usually come with all that you need to clean your shotgun, and can be found in your local sporting goods store. I use "Hoppe's Shotgun Cleaning Kit" which I bought from "Academy" for eight dollars. Inside the kit should be a box of patches, a bristle, a cotton mop, a bottle of solvent and a rod. You must also purchase a box of cotton swabs and a cloth rag separately. Cotton swabs and cloth rags can be found in most local grocery stores.
STEP 2: Disassemble Shotgun
Depending upon what break-action shotgun you are using, the disassembly may be different. Because I do not want you to damage your shotgun I must ask that you refer to your owners manual for disassembly. If you are unsure of where your manual is, do not fret. Most manuals for shotguns are on the manufacturers website in PDF form. Simply type the name of the model of your shotgun into Google followed by the word "manual." You should see a link for your manual in the search results. Click on the link and follow the instructions for disassembly. When you are done your gun should look like this.
STEP 3: Locate Rod and Bristle
Find the rod and the bristle included in your shotgun cleaning kit. If you are unsure what these look like, refer to step 1. At the end of your rod there should be an adapter. Screw the bristle clockwise into the adapter until tight.
STEP 4: Run Bristle Through Barrel
Now that you have attached the bristle to the rod, it is time to run the rod through the barrel. This is to clean out any hard residue that may have gotten stuck to the inside of the barrel. Place the muzzle of the barrel towards the ground, and hold the rod in the opposite hand. From the breech, stick the rod inside the barrel. Push the rod through to the end of the barrel. Then pull the rod back up towards you. Continue to push the rod back and forth through the barrel about ten times. If your break-action shotgun has two separate barrels, apply this step to both barrels.
