The Breeze - a Easy to Make Paper Airplane
Intro: The Breeze - a Easy to Make Paper Airplane
The Breeze is a durable and easy to fold paper airplane that will deliver very consistent and precise flights. To make this paper airplane you will need only a single sheet of paper.This is a easy to make long range airplane.It is a fun to make airplane which can fly outdoors and indoors both (Outdoors when a strong wind is not blowing).The longest that I got it to fly was 50 feet
This instructable tells how to create the Breeze,make some changes,how to fly it.
This instructable is an entry in Paper Airplane Contest 10
STEP 1: Materials
Materials Required :
~ A NoteBook Sized Paper ( 24cm by 18cm)
~ A Ruler ( For Precise Folding)
STEP 2: Start Folding
~ Fold a sheet of paper exactly in half long-ways, and re-open it so you have a crease separating the two halves.
~ After unfolding the paper you will see a centerline which will be used as a reference point in all our steps.
~ On one end on of the paper, fold each corner in towards the center to the point where the inside edges are even with the centerline crease.
STEP 3: Some More Folding
~ The bottom edge of the corners that you just folded down should create a straight line across the page. Fold down at this line.
~ Fold the corners down again similar to what you did in the previous step, but this time only the corners should meet in the middle - leave one to two inches of straight paper at the top.
~ Where the corners of the last folds meet, you will see the point of fold 3 poking out of the bottom. Fold it up and over the two corners
STEP 4: Finishing Up
~ Turn the paper over onto the other side and fold it in half.
~ Fold the first wing so that the outside edge runs parallel to the body.
~ Fold the second wing exactly as you did the first.
STEP 5: Fine Tuning & Flying
Fine Tuning:
Throw the Breeze in the air see how does it react.
Your Breeze may need some fine-tuning before it will fly perfectly straight.
If it dives, slightly angle the rear of the wings up.
If it climbs and crashes, slightly angle the rear of the wings down.
Flying:
Hold the Breeze along the centerline and push it forward through the air.
Flying:
STEP 6: All Done!
By this point of time you have mastered making and flying the Breeze .I hope this paper airplane inspires further experimentation and improvements in design to make the Breez Version II.If you have any queries feel free to leave a comment or send me a PM or E-mail me at r1398ohit@gmail.com
13 Comments
kylebrown01 8 years ago
it works!
blinkyblinky 12 years ago
Jespahyy 9 years ago
correct
Noble_Knight 8 years ago
agreed straight out of the klutz paper airplane book
Jobwar 8 years ago
that was easy i made it but i cant post pictures for some reason
this is called the Nakamura Lock not the breeze
tiddlebitter 9 years ago
too easy. :(
roborto1999 10 years ago
Thankyou so much for this airplane its brillant :)
Tuinopo80 12 years ago
dillydo 11 years ago
Bot1398 12 years ago
theswordninja561 12 years ago
