Introduction: The Cart of the Past
By: Mike and Taylor
Step 1: Frame Construction
1. Buy Two 10 foot long 3/4 thick conduit
2also buy to 90 degree connectors
3. Cut conduit 3/7 on both
4.attach connectors and screw in
Step 2: Get Four Pieces of Wood and Put Them on the Cart As Shown.
preferably buy 2 full length 2 by fours and cut them in half and attach with conduit attachers
Step 3: Get a Square Piece of Wood and Drill It Down to Make a Seat
Any semi durable ply wood will work
Cut to match the area of the four planks if necessary
Step 4: Add a Back Rest.
use whatever remains of the piece of plywood as main backrest
Cut two triangular pieces of the same angle and screw them down onto the base.
screw main backrest over giving a leaning angle
Step 5: Make Two Big Wheels and Two Small Wheels Out of Wood Using a Precision Saw
Make sure you use at least two inch thick wood
The two large wheels should match in size and the small wheels should match in size
Sand sand sand!!!!! Make them as smooth rolling as possible
Step 6: Attach Pieces of Wood to the Wheels to Make Them Stay Together.
simply take any 2 by 4 with the right length and screw them to wheels to hold wheels in place
Photo will show this easily
Step 7: Unscrew the Metal Frame and Put the Wheels On.
unscrew the metal frame and slide the wheels on
Step 8: Make Sure You Put the Wheels Where You Want Them Then Put the Screws Back Into the Frame.
set wheels in preferred location on frame
2 Comments
6 years ago
Cool
7 years ago on Introduction
That's a great looking cart! I'm excited to see more from you in the future!
