Introduction: The Chair on Skies
The perfect low cost, creative product for the middle of winter, that is tons of fun and gives you a creative project to do.
Step 1: Supplies
A metal folding chair
An old pair of cross country skis
A drill with a 1 inch drill bit
Zip ties
Silicone
And a screw driver
Zip ties
Silicone
And a screw driver
Step 2:
I don't have step by step pictures but it's easy enough to explain. So first take of the bindings using a screw driver.
Step 3:
Then when the bindings are off center the chair on the ski and draw a circle around where the leg touches the ski.
After that drill a hole in the center of the circles using the 1 inch drill bit. (Do this to both skies so the holes line up)
Step 4:
Next drill a 1/4 inch hole 1/2 inch behind where you drilled the 1 inch hole. Then put silicone in the 1 inch holes and place the chair in place. The last step is to put a zip tie through the 1/4 inch hole around the cross support for the chair and pull it tight. (Use the picture for a reference)
Step 5:
Your done, have fun and be safe!
