Introduction: The Co-Archiving Toolbox
The Co-archiving Toolbox concept is developed by the research project Co-archiving, which aims to explore and prototype collaborative (co-) archiving practices, that invite underrepresented voices to contribute to our common archives. The target group for the Co-archiving Toolbox is not only the unheard, but also archivists and museum professionals who are interested in assuming a co-archiving facilitation approach by engaging the subjects (the documented) in the shaping of archives. The underlying assumption is that inviting more people to contribute to the public archives would result in a more diverse and representative record of human existence.
The project is part of Living Archives, which is an interdisciplinary research project at School of Arts and Communication (K3), Malmö University, funded by the Swedish Research Council.
The toolbox was developed in collaboration with the Refugee Documentation Project run by the Regional Museum in Kristianstad, Malmö Museums, Kulturen Museum and the Department of Cultural Sciences, Lund University, aimed at documenting the emergent refugee situation in Sweden.
With this instructable you can create from scratch your own co-archiving toolbox, select and adapt the practices that it will hold and plan your own co-archiving project using the toolbox.
For more information about the Co-archiving Documentation Project, contact:
- Elisabet M. Nilsson, elisabet.nilsson@mau.se
Sofie Marie Ottsen Hansen, sofie.marie.ottsen.hansen@mau.se
For more information about this build and the toolbox design:
- Max Paulsson Hall, max.paha@outlook.com
Student, Bachelor of Arts in Product Design, Malmö University
Step 1: Tools and Materials
Tools needed:
- Laser cutter
- Soft hammer
- Sandpaper
- Bowl of water (for wood bending)
- Sponge (for wood bending)
- Random box or books (for assembly)
Materials needed:
You can choose to make the whole toolbox in the same material or use different materials for the inside and outside. You can also choose to make the compartment floor in clear plastic so that you can see the archived documents.
Option 1 (one material)
- One sheet of 4mm MDF (2440x1220 mm)
Option 2 (two materials)
- Inside: 3/5 sheet of 4 mm MDF with veneer (1460x1220 mm)
- Outside: 2/5 sheet of 4 mm MDF with veneer (980x1220 mm)
Extra option (see-through floor)
- Compartment floor: 4 mm of clear plastic (600x450 mm)
Step 2: Drawings and Adjustments
We have uploaded 3D-CAD, 2D-CAD and Illustrator files of this project so that you can make any type of changes you want if you have the knowledge.
For those of you that just want the toolbox as is, can follow the instructions on the step bellow and make the necessary adjustments to the illustrator files.
Step 3: Determine the Kerf
Find out what your laser cutters kerf is. The kerf is the width of cut that your laser cutter makes in the specific material you are using (in this case 4mm MDF).
There is a great instructable of how to do this which you can find here.
When we followed this instructable we made a metric version of the files with instructions inside (see below).
Step 4: Adjust the for the Kerf (or Not)
If you are lucky and your kerf happens to be 0,2 mm then you can use the same file as we used to cut the toolbox. This file is already adjusted for a 0,2 mm kerf.
If your kerf is something other than 0,2 mm then you need to adjust for this by making offsets in illustrator. We have prepared a file with instructions of how to do it inside.
Step 5: Laser Cut the Toolbox
Inside the illustrator file you just adjusted (or not) there is 10 different artboards. The artboards are 600x450 mm (the range of the laser cutter we used).
Simply send one or more artboards to your laser cutter depending on your cutting range. If your laser cutter has a completely different dimension you should create new artboards with the right dimensions. Then simply drag the shapes over.
For those of you that want different types of MDF for your toolbox should cut artboard 1-6 (inside) in one material and artboard 7-10 (outside) in the other material. The compartment floor can be found on artboard 1 for those of you that want it to be in clear plastic.
The engraving lines are blue and should be cut first, the hinge patterns are red and should be cut second. All the other lines are black and should be cut last.
Step 6: Assemble the Toolbox
Once all of the parts have been cut out it’s time for assembly. For this we have made a video tutorial for you to follow. To keep track of all the parts that's mentioned in the video we have made an assembly document which we recommend you use along with the video. In this document you can see exactly what parts are referred to in the video.
Step 7: Select, Edit and Add Practices for the Toolbox.
The toolbox can be changed and adapted to any setting. Using the toolbox is a highly situated practice, an emphasis thus ought to be put on the importance of adjusting and adopting the toolbox to the situation and the subjects of the archive.
Print all labels, instructions and materials and attach and place them in the toolbox. Gather any other materials needed for the different practices (camera, recorder, pens, paper, envelopes etc) and place in the toolbox.
Step 8: Prepare Field Deployment
Set the aim of the project, decide on a location for deployment of the toolbox and collect information of participants. Use the co-archivist handbook for structuring your engagement with the field.
3 Comments
3 years ago
just love this
4 years ago on Step 7
Such an awesome project and I love living hinges. Thanks for the post!
5 years ago
Such an interesting and well-documented project! Thank you for sharing.
