The Easiest Way to Soft Mod an Original XBOX
Intro: The Easiest Way to Soft Mod an Original XBOX
This Instructable is taken from gh3tt0h4x0r on Youtube (including screencaps, as my Gamebridge was being weird the night i did this). His two part video shows how you can do a simple install of the XBMC (XBox Media Centre) on an XBox without the need for Action Replay, a memory card or compatible USB thumbdrive (i used my Kingston 4 gig, He used a PSP). This is simple, Links are provided off this site (due to size) for this install, and the only long part to this is the copying of files at certain points. I have done this myself and i must say that this was a no-brainer!
STEP 1: Getting Started
You will need the following:
USB thumbdrive (at least 512 Meg is a good size, as this is a big install)
the softmod install files (updated file location as Megaupload is now dead: http://www.1337upload.net/files/SID.zip)
Xplorer 360 (Program that allows you to inject files onto the Thumbdrive)
Decent computer running Windows XP or Windows 7 but will be testing under Wine in Xubuntu (I GUESS you could use Vista :S )
Device to connect Thumbdrive to XBox (i used my Controller
Game that can use an Exploit (I used the First Splinter Cell as any version will work. If you can't get that, the Original Mech Assault, or an Older version of 007:Agent Under Fire, as most of the newer ones will not work.)
Original XBox
Optional: 12 pack of your favorite frosty 'BEvERage'
Original XBox
STEP 2: File (and How to Prepare Them!)
Boot up your Xbox without a game in the drive then go to memory. Make sure your thumbdrive is plugged into the controller or otherwise connected to the XBox. Your XBox will say that your thumbdrive is not working correctly and has been erased (i hope you didn't have anything valuable on it!). After this, simply plug that sucker into your computer. when the PC identifies the drive, it will ask if you would like to format it. Don't! Install Xplorer 360 to the desktop and as well, extract the NTSC folder within the compressed folder to the desktop as well. then start X 360 and go to >Drive >Open >Hard Drive or Memory Card. It will identify the thumbdrive as Partition 0 (the thumbdrive has been formated by the XBox as FatX so your PC will not recognize it on its own). Now Drag 'N' Drop the four folders inside NTSC to the right hand of the X 360. This will take about 15 minutes or so as the files aren't simply copied, but 'injected' onto the thumbdrive. So crack a cold one and throw on something to pass the time (it was Hulu for me :D and yes i am in Canada, but i know a way around that ;) )
STEP 3: Copying Files From Stick to XBox
Once the Files have completed injecting onto the stick, you can now plug it into the XBox. You will want to access the Memory section of the Dashboard, then select the area where the thumbdrive is recognized (in the case of my install, it was Controller One). You will want to open that part, then press Right (->) on the D-Pad on the controller then copy the appropriate save file to the hard drive (in this case, The Splinter Cell Linux save). Now this will take a while again to copy, so its good to have something to do. This should take about ten minutes (blame the USB 1.1 connectivity of the XBox). when this is done you can check the hard drives contents in the Memory Section to confirm. When this is done, exit all that then remove the thumbdrive. Now load your Game and on to the next step!
STEP 4: Installation (the Not-nearly-as-slow Part!)
Ok, no worries the long parts are past us, as the files are now on your hard drive! Boot the Game now (hit start to skip past the opening). Go to the Start Game Screen, and select the "Linux" profile. Hit A three times then watch the system load onto the BSOD installer (B@$tard Sons Of Dialup). You will now only have a few simple steps to follow. First, in case something like a power outage or other Act of Randomness inturrupts the install, select "Back up C Drive" first off! Confirm by selecting Yes after you start the backup process, and this will only take maybe a minute (it's all being done on the hard drive now so it's a LOT faster!). When that is completed, select "Install Softmod". This will load into a different screen where you will see a scroll down menu. Select "Backup EEEPROM". Then back it up to the E Drive. This will take a second. Then select "Install Softmod". this may take 3 to 5 minutes. once this is done, select "Back To Main Menu". Then select "Restart XBox".
STEP 5: The Fruits of Your Labours!
Just restart the XBox now and enjoy the payoff! XBox Media Centre will play any file format that you throw at it, including MP4, MKV, OGM, DIVX, Xvid, and supports iTunes Network Play, album art, and some kick-ass emulators (those you will have to install yourself besides FCEEmu (NES Emulator included with the installation, but you have to supply the roms, naturally). Now i do not recommend playing movies off of the USB as it is only 1.1 (slow data transfer rate). Network or DVD Drive is recommended (that may be in another tutorial). As well, this WILL allow you to play Backups (burned games) but if you make your own backups, burn them at a low speed, and use DVD-R (some drives have been shown the ability to recognize the +R, +RW, as well as CD-R). Enjoy!!
378 Comments
mattstar1980 3 years ago
Beedalator 3 years ago
Many Thanks
knopix 5 years ago
https://drive.google.com/open?id=1ePIktEc3c--GLZYhR-tp74h5ycVHH_AE
jeremym201 6 years ago
This memory stick works great
http://www.ebay.com/itm/371577006299?_trksid=p2057...
some things have changed follow martinK3's comment
justanotherlittle 7 years ago
MharJ1 7 years ago
same with me paps
MartinK3 7 years ago
Just thought I'd add a comment as I softmodded my original xbox last night and used this guide as a basis. Obviously things have changed a little since it was posted but overall this was a good guide.
Firstly, I struggled to find a flash drive that would be recognised by the Xbox. I think everything I tried was probably too new (USB 3.0 drives) or too large. I found an ancient 128mb flash drive that was detected ok but that was too small for the exploit to copy on to. In the end I used an old 512mb memory card plugged into a USB Card reader and that was detected and erased by the Xbox fine.
Secondly, the download link for the softmod installer was no good for me, I think it only has part of what you need.
I googled for "Splinter Cell soft mod NTSC" and eventually found this site that had the files I needed and a little more detail on which ones to copy onto the flash drive. http://www.theisozone.com/downloads/xbox/tools/sid...
Otherwise everything else is much the same, use Xplorer 360 to "inject" the files onto the flash drive, copy them over to the xbox hard drive and then load up Splinter Cell or whichever game you're using and load the same game from the hard drive.
Next up I need to get a bigger hard drive in there and also get some emulators copied onto it!
bandora 7 years ago
Thanks for the update.. Is Splinter Cell absolutely required? I have Halo 1 & 2, NFS Hot Pursuit, and Counter-Strike. Would any of those work?
I was able to pickup a boxed copy of Splinter Cell for five bucks from a store near me recently and I think it's the easiest one to find out of the three.
bandora 7 years ago
Thanks for the info! :)
Joao PauloA2 8 years ago
What should i do ? please tell me step by step
alex9900 10 years ago
Hi! I want to do this to run classic console emulators, like NES, Super Nintendo, Sega Genesis, etc. How do I install the emulators and roms? do they run from the USB thumb drive or can I burn them into a dvd that runs in the xbox?
AlynD1 8 years ago
Try this with modding xbox 360 software very simple steps www.moddingxbox360.blogspot.com
TheDoctor64 9 years ago
Which Usb drives plus does it have to plug into the memory slot or can it just plug directly into the xbox
AlynD1 8 years ago
AlynD1 8 years ago
c4ptainlaur3n 9 years ago
ghguti0101 9 years ago
zulfiqarmalik01 9 years ago
you got your xbox mod-chipped by him most likely
gwatts1 9 years ago
ok I have updated dash and formatted 4gb sandisk cruzer edge with the xbox original and have put it in pc I didn't see no message about formatting the drive although it installed a driver for the cruzer edge. my computer don't show the drive but it shows in device manager. I right click on xplorer360 and select run as administrator I select open hdd and get a message can't find fatx drive. I'm using windows 7
