Introduction: The Element Stones
So I made this as little decoration for the top of my PC and they give a little place to stash small items where people wont think to look.
3.8 mm plywood
Laser cutter
Bees Wax
sand paper 400G
CA glue
Step 1: Download the Files
The files are design to work on a k40 laser system with a bed size of 300mm by 200mm
Step 2: Cutting
I used K40 Whisperer to print these files. In the advanced settings combine the engraving and cutting tasks
The setting for the engraving should set at 300mm/s and the cutting at 10mm/s and the laser power was set to 90%.
Step 3: Glueing
Use the CA glue to stick the pieces together
If you wan to use these as secret boxes then do not glue the top on.
Step 4: A Quick Rub
The stones need a quick going over with sand paper to remove any soot/charing left over from the laser cutter and then a quick rub down with some wax to protect the wood and give them a little shine.
I hope this instructable helps you create your own stones. I am happy to answer any questions you may have.
