Introduction: The Fastes Shelf EVER.
MATERIALS
1. CARDBOARD ROLLS
2. BAND SAW(TECH SHOP)
3.PAINTER TAPE
4. WOOD GLUE (THE BEST)
5. SANDER (OPTIONAL)
6. TWO TACKS OR NAILS OR SCREWS
1. CARDBOARD ROLLS
3.PAINTER TAPE
Step 1: FRIST STEP
USING AT LEAST 4 LARGE CARDBOARD ROLLS
WALK OVER TO TECH SHOP AND USE THE BAND SAW TO CUT YOU ROLLS UP INTO SMALLER SECTION
TRY A VARIETY OF SIZE MAYBE 4" LENGTH -2"
PLAY AROUND WITH DIFFERENT LENGTH
SANDING IS OPTIONAL!
Step 2: STEP TWO
ARRANGE ALL YOU CUT ROLLS ON THE TABLE IN ANY CONFIGURATION YOU LIKE
MAKE SURE ALL THE ROLLS TOUCH EACH OTHER THE MORE SIDE THAT TOUCH THE STRONGER THE SHELF
* GLUE SIDE THAT TOUCH USING A BRUSH AND GLUING ONE SIDE AT AT A TIME
Step 3:
NOW THAT ALL HAS GLUE WRAP PAINTERS TAPE ALL AROUND NICE AND TIGHT NOT TOO TIGHT OTHER WISE YOU DESIGN WILL FALL APART
GET A HELPER! IT HELPS
LET IT DRY FOR AT LEAST 4 HOURS.
ALMOST DONE
ALMOST DONE
Step 4: STEP WALA
HANG USING A TWO NAILS FROM THE TOP TWO ROLLS THAT ARE ON THE TOP OF YOUR DESIGN. THE NAILS ARE NAIL IN PLACE THEN PLACE TUBES ON TOP
YEAH I KNOW I SAID TOP 4 TIME S
