Introduction: The Fastest Way to Tie a Tie - How to Tie a Tie in Less Than 10 Seconds
This is known as the fastest way to tie a tie. Get it done in 10 seconds. Just in the case you are going to be late to your work, you can use this way to tie your tie. I show you how.
This tie tricks is full windsor, but you can adjust it into half-windsor knot as you want.
This instruction come with video, so you can repeat watching it as many time as you want.
First Step: turn it over and put the tie like this position
Step 1: Hand Tricks
Twist you hand and insert you hand into the hole, then hold it with you thumb
Step 2: Turn It Over
turn it over and insert you hand into the other hole
Step 3: Hold It With Your Thumb
hold it with your thumb and insert the tail in the hole here
Step 4: Hold the Tail With Your Right Thumb
hold the tail with your right thumb,
Step 5: Adjust It
Adjust the position carefully
Step 6: That's All
This all
Step 7: See
here is the completed tie, is that beautiful. this instruction come with video
