Introduction: The Full "How To" Manual for EL (Electroluminescent) Wire
Disclaimer : This is my First Instructable. I appreciate any constructive criticism and helpful advice. Now any of you who just ramble on about “I’m just in it for the money” or “You misspelled instruction” or “He’s trying to control the world” just leave me be and we'll be just fine. (Ok, the World Domination may be true.)
Now I don’t claim to know that I am the end all knowledge on EL wire but I have done my research before I bought anything, plus, I have compiled what it’s made of, what makes it work, some history, and helpful tips to help you out. So let's get started.
Step 1: What Is EL Wire?
EL wire's construction consists of five major components. First is a solid-copper wire core. This core is coated with phosphor. A very fine wire is spiral-wound around the phosphor-coated copper core. This fine wire is electrically isolated from the copper core. Surrounding this 'sandwich' of copper core, phosphor, and fine copper wire is a clear PVC sleeve. Finally, surrounding this thin, clear PVC sleeve is another clear, colored translucent, or fluorescent PVC sleeve.
An electric potential of approximately 90 - 120 volts at about 1000 Hz is applied between the copper core wire and the fine wire that surrounds the phosphor coated copper core. The wire can be modelled as a coaxial capacitor with about 1 nF of capacitance per foot, and the rapid charging and discharging of this capacitor excites the phosphor to emit light. The colors of light that can be produced efficiently by phosphors are limited, so many types of wire use an additional fluorescent organic dye in the clear PVC sleeve to produce the final result. These organic dyes produce colors like red and purple when excited by the blue-green light of the core.
Thanks to Wikipedia and Electronics Warehouse for information.
(Picture credit: http://en.wikipedia.org/wiki/EL_wire )
Step 2: Let's Build Something!!
Tools:
Solder Gun
Wire Cutter / Stripper
Shears
Heat source (Flame, Heat gun, 5 alarm chili fart)
Supplies:
EL wire - any amount you need for your project (I suggest that you add 10% extra just to make sure you have enough)
Power pack - several internet shops sells cheap inverters
Srink wrap - Several different diameters as well as lengths
solder
copper sheet
connectors
Lastly, you need a place a to work with good lighting. I also would have liked to have a third hand (device with clips and a magnifer).
Step 3: Time to Run the Wire
After gathering your supplies, it’s time to give them something to do. Most inverter/power supplies I found online all had a connector on them. Most shops also supply the male connector for the power supply but not all. Take one side (doesn’t matter which side) and strip the PVC sleeve off.
*** Don’t cut through the Angel Wire ***
I would suggest using an exacto knife but it is not required. You can start ½ inch from the end but until you become skilled with EL soldering, it would be easier to start about an inch in. (I did that - the slop can be cut off later). Spread the angel wire apart for later. Next you will need to remove the phosphorous layer around the copper wire. This is the where the wire cutters come in. Place the wire in the cutter and avoid cutting the wire “skin” off the phosphor layer.
*** Warning: Don’t remove the phosphor with your teeth. There are many types of phosphor. Some are toxic, most are luminescent. This can make you sick (plus it made my mouth taste funny all day. Learn from my errors!) ***
Now you should have a something that looks like the picture.
Step 4: "Scotty, I've Got to Have More POWER!!!"
Now plug it into the power pack and see it glow!
Step 5: Better, Bigger, Badder
And here we go. On top of the listed item in step 2 you will need:
Copper tape (or copper sheeting with an adhesive backing)
More shrink wrap
And tons of patience
Step 6: Better, Bigger, Badder
On top of the items listed in step 2, you will need:
More shrink wrap
First you need to prep all the EL wires striping them of both the PVC as well as the phosphor coating. Solder one wire to another. Shrink wrap the connection and making sure that you cover all of the exposed copper wire and heat. Next the you cut the copper sheet into a small strips. Now here you can have some freedom with connection, You can wrap the copper around the PVC of one wire or you can wrap it around the shrink wrap or you can lay the strip along one side of the shrink wrap. I choose the laying method to allow better contact point for the angel wires. After placing the copper solder the angel wires of both EL’s to the copper.
***Soldering should be done quickly to avoid melting the shrink wrap or the adhesive on the copper sheet.***
You can do this separately or how I did it was placing all four wires laying flat on the copper sheet and then soldering them at the same time. After allow the solder to cool (couple of seconds should do it) wrap it with shrink wrap heat and there is your finished product.
You can do the process many time with different lengths of EL as displayed. I have read online that 50ft of EL wire can be powered by a single AAA battery, but I wonder about that.
I hope you found this a helpful guide to the wonderful world of EL wires and found it quite illuminating. (Sorry I had say it.) Please see the last page for further ideas, last minute insights and other EL links.
Step 7: Fleeting Thoughts
First, all my EL wire was purchased from thatscoolwire.com. They have several great deals as well as cheap sample kits and a 20ft grab bag offer that was most helpful. (See pics.)
Second, a warning: if you play with the bare connections, even though it is only 1.5 volts, it will still give you a nice little shock. (I was adjusting the shrink wrap while the circuit was live.)
Lastly, I think this "Dasiy chain" would also work if, instead of soldering the wires, you added a connector which would allow you to change up the color order at will. I think an SBA connector would do the job. I may continue experimenting with it and will post any findings.
Topic Items - Reference
http://en.wikipedia.org/wiki/Electroluminescent
Suppliers
thatscoolwire.com
http://www.elwire.com/
http://elbestbuy.com/
http://www.coolneon.com/
http://fiberopticproducts.com/El_wire.htm
www.elwirepros.com/
www.coolight.com/Default.asp?Redirected=Y
