Introduction: The Garbage Bag Blinking Ghost
i just finished making a garbage bag ghost with led blinking eyes. I hope you build one also and have as much fun as i did.
Step 1: Materials
The materials are as follows-
-two ultrta bright leds
-garbage bag
-8 pin dip chip holder
-rubberband
-paper
-arduino
-4 ft pvc pipe, 1/2 or 3/4 inch
-wire for connecting
-garbage bag
-rubberband
-paper
-arduino
Step 2: Prepare the Chip Holder
solder all 4 pins on each side to a wire for each side.
Step 3: Insert Leds
put the leds in parallel across the holder and bend out each one.
Step 4: Code
not much more to say. connect red wire from led assembly on pin 10 and black on ground here it is-
void setup() {
pinMode(10, OUTPUT);
void loop() {
digitalWrite(10, HIGH);
delay(3000);
digitalWrite(10, LOW);
delay(100);
void setup() {
void loop() {
delay(3000);
delay(100);
Step 5: Packaging It Up
take the arduino board and crumple some paper around it.
finish with a full sheet and wrap it around the crumpled sheets
pull the trash bag over the assembly and rubber band it at the bottom with the pvc
Step 6: Completion
stick the pvc pipe in the ground and power the arduino.
HAPPY HALLOWEEN AND PLEASE VOTE FOR ME IN THE HALLOWEEN CONTESTS FOR PROPS AND DECORATIONS
