Introduction: The GorillaTape Gorillapod! (flexible Tripod Under $10)
EASY and QUICK instructions on how to build a flexible tripod that can support heavy cameras like DSLR's.
When you are finished, it will be just as strong as the $70 name brand Gorillapods, but will cost you less than $10... (Less than $4 if you already have the tape).
Step 1: Materials and Tools
All materials can be found at Home Depot, or any other local hardware store nearby.
Tools:
Pliers
Wire cutters
Bare Hands
Materials:
small roll of Gorilla Tape ($5) (free if you already have some, or borrow from a friend)
1/4" x 2" Hex bolt ($0.19)
strong electrical wire (3 feet) ($1.07 / ft) = $3.21
I don't know what the specific wire I used for this instructable is called, but it has 5 wires inside, wrapped in a yellow cover. If you can't find this, just look for insulated wire that will be strong enough to support your camera. I prefer thicker wire that has rubber insulation.
Step 2: Cut and Bend
Cut the wire evenly into 1 foot segments and bend the ends as in the photo.
Each U-bend is approx. 1.5" long.
Step 3: Tape
Rip off about 6 inches of the tape.
Rip into skinnier strips.
These will be used as primary attachment of the wire to the bolt.
Each time you apply tape, do it VERY TIGHTLY.
The GorillaTape can definitely handle it, and it will make your Gorillapod a lot stronger.
Tape the first leg to the bolt as in the photo.
Tape the second leg right next to the first one, and of course,
tape the third one down.
Your tripod should now look like the one in the 3rd photo.
Finally, wrap this section up like in the photo, making sure the bottom is tightly taped in place so that the bolt cannot slip downward.
Step 4: Take It to the Jungle
Now screw it up to your camera, and get out there!
The beauty of this design is how simple it is, how STRONG it is, how cheap it is, and how adaptable it can be.
Since YOU are the one building this GorillaTape Gorillapod, YOU have the power to choose the length of your legs, and even how many legs you want. If you feel like you should have an 8 legged pod, then build it that way!
Build it to suit your needs, and enjoy!
Feel free to leave comments and let me know how yours turned out...
Homemade Holidays: Holiday Gifts
15 Comments
5 years ago on Introduction
Hi,
I've added your Instructable to the "Top 5 GorillaPod Tripod Hacks!" collection!
This is the link If you are interested:
https://www.instructables.com/id/GorillaPod-Tripod-...
8 years ago on Introduction
If anyone cares, I found the exact wire- http://www.amazon.com/Southwire-63947601-Metallic-Sheathed-Cable-Copper/dp/B000BQM470
Just google "63947601" and you'll get it
11 years ago on Introduction
I joined the community specifically for this project just made mine got the material from lowes, they didn't have the same wire.. mine is Orange with 3 thick wires.. I will see how it work so far its exciting, how long have you used it has it shown any signs of wear? I will be doing the Plasti-dip as well great idea! Any thoughts on how to add a ball mount that isn't $20+ to it? I am looking myself, let me know if anyone comes up with something!
I realize this is an old comment, but has anybody come up with a manageable answer on a DIY ball mount yet?
Thanks, and a fantastic 'ible!
9 years ago on Introduction
This sounds like a perfect use for sugru
10 years ago on Step 4
eight-legged pods should be called octopods, not tripods
10 years ago on Introduction
I am building this as we speak. Great work!
10 years ago on Step 3
This is a GREAT idea. Just realized you could use HOSE CLAMPS instead of tape to connect the bot to the wire. They are cheap and strong. You could still cover the connection with tape if you wanted. To make things even neater, you could also cover the connection to the bolt and the ends (feet) of the wire in shrink wrap, too.
I created something very similar. We had some unused 12awg wire at work, so I used doubled up pieces for the legs, then I put some heat-shrink tubing on them. I used a large crimp-on lug instead of the tape. I put a 1/4-20 bolt through the lug, and used a couple nuts to make sure the bolt was secure. I've been meaning to make another one, because of a design feature I want to add. I've been using the 1st gen for about a year and a half, and decided that I want to add a 'neck' to the 2nd gen. I've wrapped mine around rod sign posts to get group shots of my cycling group, and the neck will make it much easier to 'straighten' the camera so I get a mostly level shot.
Dude...I've been reading a lot of DIY photo stuff and this is the most under rated project. This thing is awesome. I did make a couple of additions to mine though. I built up the tape on the ends to create a type of foot and then I plasti-dipped the ends and the top. after it dried i justed cut and peeled it off the threads. Looks store bought. Thanks again for this great project!
Reply 11 years ago on Introduction
Hey, thanks! I really appreciate that... I'm a product design student at the University of Houston and I always like to hear feedback on my designs. Yeah, the design has changed a bit since the comments I've received, and your plasti-dip addition was genius... I actually have a can of it that I've been trying to figure out what to do with. I wanted a gorillapod, but they are too expensive, and all the DIY gorillapods online at the time needed too many expensive parts and too much work to do a simple task! So, I just went to home depot one afternoon to figure out what I could do, and this was it! Thanks again - Keith
I hear ya. I'm starting to find that you are better off saving your money for the camera and lenses because the rest of the stuff is pretty much DIY. Oh by the way I also forgot to mention I used some epoxy equivalent to "Mighty Putty" on the top to hold the wire and bolt steady. Added a whole $3 bucks to the build. I think my total cost for this tripod was $10 bucks. Here is a pic of my final product.
Wow! that DOES look store-bought... nice job
12 years ago on Introduction
Great idea. I was going to buy the bits for a DIY gorilla pod, but I just made one of these for nothing - I had all the bits already!! I changed a few things on mine: to make it more robust I cut about an inch of the foam off the ends of the wire, and I used jubilee clips (hose clips) instead of tape to bind everything together. I found that if you're using it as a plain tripod on a table the legs slip a bit, but you can hook the legs together to make a tetrahedron shape, and then it's rock solid.
Great idea. I might have to do it some day.
