Introduction: The Graveyard 2.0
I designd a graveyard but with a twist.
Step 1: Explore Tinkercad
Sign up for a tinkercad account.
I clicked add new design, then I started looking through the shapes.
I found shapes that reminded me of the game Among Us.
I started moving the shapes into the work plane.
I moved the shapes around to see what I could do with them. I made them bigger and smalller. Sometimes I made them flater and wider. I changed their color. I just explored what I could do in Tinkercad.
Step 2: Recreate This
You will need the following forms in your work plane.
4 cylinders
4 half cylinder
1 cone
1 flat sphere
2 rectangular prism
It does not matter what color your forms are in tinkercad.
Step 3: Group Forms
I immagined what my end project would look like.
I chose the forms that would need to print the same color and decide to group them.
The first group was needing to be printed in green. I included 2 cylinders, one rectangular prism and 2 half cylinders.
The seond group needed to print in black and it was just 1 rectangular prism.
The third group need to print in red, it was one half cylinder
The fourth goup need tp print in blue another half cylinder
The last group was white just one cylinder as well.
Step 4: Print
Double check you have the correct color fillament in the printer. I stared with Green. Print all of your green group.
After your green group prints you will change the fillament to black. Print all forms in your black group.
Chang your filliment to red and print your red group.
Change fillament to blue and print blue group.
Change fillament to white and print your final group.
Stay near the printer so if anything goes wrong you can stop the print and not waste fillament.
Step 5: Hot Glue
I assembled the project with hot glue.
The first thing I glued was the white cylinder on top the the green rectangular prism. Next glue the two green half cylinders on the short sides of the green retangular prism. Next I hot glued the two green cylinders on the bottom of the green reguangluar prism.
Next I hot glued the black rectagular prism on the back of the red half cylinder. Then I glued the blue half cylendar on the front of the red half cylinder.
Step 6: Cardboard
I found a cardboard box and decided it would fit my porject perfectly.
The box I used was 9 inches wide, 8 inches tall and 7 inches deep. However you can use any box you think would work.
I decorated the box using black construction paper and white paper that I colored grave yard fence on. then I added a plastic bat.
Then I cut the top off the box and cut one side off, that way you can see inside the box.
Step 7: You're Done:D
Enjoy the grave yard sceen that you have created.
