Introduction: Thin Line Paracord Bracelet
Tired of the usual cobra weave? If so, this is for you. This bracelet can be unraveled for a good amount of cord.
It's a very stylish bracelet. The weave is very similar to the
cobra weave, so if you've ever done the cobra weave before, this
should be a piece of cake. Even if you haven't done the cobra
weave before you shouldn't have any issues with this one.
It doesn't use a buckle.
Step 1: Gather Supplies
Supplies:
6 feet of black paracord
Yellow paracord*
Lighter
Scissors
Measuring tape
*To figure out how much cord you need, wrap it loosely around your wrist twice and add about 4 inches.
Yellow paracord*
Lighter
Scissors
Measuring tape
Step 2: The Shorter Cord
Fold the shorter cord in half and tie a knot at the end.
Step 3: Preparing the Weave
Fold the longer cord in half. Lay the shorter cord over the halfway mark of the longer cord with about a half an inch above.
Step 4: Starting the Weave
Lay the left piece of the long cord over both of the shorter cords. Grab the right long cord, pull it over the left long cord, behind both of the short cords, and up through the hole marked with a red dot on the picture. Now pull it tight.
Step 5: Second Part of the Weave
After the first knot, you alternate each side you pull the cord from. To start the second part of the weave pull the cord over the left shorter cord and under the right shorter cord, now it's the same as the first part of the weave.
Step 6: Repeat Steps 4 Through 5
Now repeat steps four through five over and over again. Do that until you run out of room or cord.
Cut the excess cord and burn the ends.
Step 7: You Are Done!
You have finished making your bracelet! You can smile now.
