Introduction: Null
HuFr stands for House used Furistic Robot. It is ueful in handling all the daily household activities done by humans in their home. It can wash the utensils, clean the floor,can take photos,record videos, acts as a projector and it can even run. The Head as in humans acts as the Control Unit which controls all the action of the robot. It performs actions based on commands given as input through hearing device and can also act on its own based pre-defined commands. The Hands and Legs are capable of rotating,revolving and twisting based on the joints provided to it. These joints are magnetic and are attached to the body strongly, and magnetic effect can be removed if the robot wanted to be serviced. The Grippers are spaced sufficiently so that they can hold larger items. The palm contains a suction pump to hold on to items by creating vacuum and can deactivate it while dropping the item. The optical sensor at the head provides the measure of light and activates/deactivates the LEDs present in the leg. It carries Infrared and temperature sensors too. The Pair of eye acts as Projector and Camera( Left and Right eye respectively). They can be auto focused depending on the distance measured from proximity sensor on the nose. The base is used to clean the floor where the vacuum cleaner and mop is present and the wheels are lowered only when the cleaning action is performed. They can be retracted once the cleaning operation is done. STOP button is provided to stop the Robot in case of emergencies. Cooling fan used to remove heat produced from the Robot It can even run. Thus, the HuFr is used to perform all actions of human and eases of their work.
