Introduction: The IRritator
What sound does annoy you most?? Well in my case it is the Nokia Tune. So I made this little gadget for the April Fools' Project Prank Contest (So if you like this little Instructable then please vote for it).
Its principle is very simple. You hide it somewhere in the living room and every time someone hits a button on any IR remote control, it will play the Nokia Tune. You might expect two possible reactions:
- They will look where they left their mobile or ask who's mobile is ringing.
- They get annoyed once they find out that the remote control triggers it, resulting in a frenzy search for the source of the sound.
Step 1: What Do I Need to Make This Prank?
You don't need much to make this little gadget.
- A buzzer
- An attiny13
- An IR - receiver
- A small battery (3V)
- A soldering iron and solder
- A bit of wire or a batteryclip to connect the battery
The IR-receiver didn't have an id-number on it but a PNA4601M should do the trick.
I used the attiny13 because it runs on very low voltages (2.7V-5.5V ant the attiny13V even starts from 1.8V)so it runs from a tiny 3V battery and ofcourse the small size is a plus in this project.
If you don't know how to program an atmel microcontroller, I should suggest you to browse around in the Instructables here. There are very good Instructables about making programmers and how to program.
Please be careful when soldering. Children should always work under adult supervision!
Step 2: Wiring This Up
Connect the + of the buzzer to pin 5 of the attiny13 and the output of the IR-receiver to pin 6.
Connect the - of the buzzer to the - of the battery.
Provide power to your microcontroller and IR-receiver by connecting the VCC/VS and Ground to the according terminals on the battery.
I added the hex-file so that you can program your attiny13.
Step 3: The Result!
I tested my IRritator and it worked pretty good. In fact there where only a very few number of spots in the room where it didn't react on the remote control.
I added a little video here for you to enjoy but you might turn the volume very high cause my camera doesn't have a good mic. In reality the sound is rather loud so I guess my mic is broken.
There is a minor inconvenience about this circuit and that is that the IR-receiver I used is in high state when it doesn't detect any IR. So even when idling the circuit will use power from the battery but It should easely last long enough to enjoy the prank the whole day long ;-)
First Prize in the
April Fools Day Project: Prank Contest
51 Comments
7 years ago on Introduction
Congratulations on winning the Pranks Contest!
Cool!
I made a Fritzing file for it with single sided PCB.
8 years ago on Introduction
Hi! I was curious, is there a way to get a c-code instead of the hex file?
Sadly the only way to get one is to write one. The originaliteit code was a basic ( bascomAVR ) code. But I don't think that I still have that one.
I didn't think the attiny has enough memory to play a ringtone. Is it an audio file, or is it just a series of beeps that you sequenced to sound like the ringtone?
It is just a series of beeps indeed. Mind you, this is an older project. Back then, ringtones were just series of beeps.
9 years ago on Introduction
Hi! Great I'ble.. so i have a question. I have a spare ATMEGA328 i can use(got it off an arduino clone). Can i use that instead of the ATTINY? (p.s, i'm assuming it already has a bootloader installed because i have uploaded sketches to it a few times.)
Sure, you can use a mega328 but you will have to write a new hex-file as this one is specificly written for an attiny13.
11 years ago on Introduction
Great instructable, I love this thing
This could EASILY be combined with https://www.instructables.com/id/Annoying-Beeper
Reply 11 years ago on Introduction
Thanks!
Yes it still works
12 years ago on Introduction
I wonder how hard it would be to wire it to respond to a incoming/outgoing cell signal. In a classroom this means anytime someone texts or gets a text it would go off. Would get really annoying and I bet a teacher would love to use it.
Reply 12 years ago on Introduction
Wow that's terribly evil. It would be funny though, except in order to do that you would need a cell phone reviver (such as another cell phone) that will react to and and revive any text frequency. that may require some pricey equipment. also it would only receive signals from other cell phones meaning that with out some sort of filter it could go off for cell phone calls anywhere within miles.
It is not very difficult to make working with cellphones I guess. You have all kinds of gadgets that make leds blink when you have an incoming call or text message. It works by induction I guess.
As sad as it is I thought of this based on an Adult toy. It vibrates when a cell within a few feet gets/sends a signal. The electronics shouldn't be to complicated since it has been applied to something like that. The internet has some weird stuff.
Would you be able to adapt their item in the toy? Or find out who makes it for them and contact them?
12 years ago on Step 1
i burnt my whole finger and my thumb. shudder
First, check out the instructible on:
"Soldering 101 - which end to hold the soldering iron"
Very funny!!!!! :D Thanks for the laugh!
my hand slipped
