Introduction: The Lock Box
This instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (www.makecourse.com)
1 Roll of 3D Printer PLA Filament
3 Stepper Motors
1 RFID Sensor
1 Arduino Mega 2650
6 Touch Sensors
1 LCD Display
1 9 Volt Battery
42 Connector Wires For Arduino
3 M3 - 0.50 x 6 Philips Machine Screws
18 6 x 5/8 Philips Sheet Screws
1 Foot of String (or Slightly Different Material)
Step 1: 3D Printed Parts: the Body
This part is the biggest and most important part of the entire build. This part has grooves for the main drawer, the first and second touch sensor drawers and for the lid. This part also includes pre-designed holes for screws that have been measured precisely.
Step 2: 3D Printed Parts: Main Drawer
This part is the main drawer, it is going to be locked in place for the most part but will be released so that any items needing security can be placed in it.
Step 3: 3D Printed Parts: First Sensor Drawer
This is the first drawer, where three touch sensors are going to be placed next to each other and held in place. This drawer is designed to be pulled out a certain amount.
Step 4: 3D Printed Parts: Second Sensor Drawer
This is the second drawer, that is going to hold three touch sensors as well. This drawer is designed to pull out from the body of the Lock Box, one-touch sensor's length allowing for you to pull out both drawers without them overlapping on top of each other.
Step 5: 3D Printed Parts: Sensor Drawer Backing
This piece is meant to fit right behind the sensor drawers the reason for this being so that the drawers themselves don't fall into the Lock Box and so that they stay within a specified area.
Step 6: 3D Printed Parts: Stepper Motor Casing 1
This casing is designed for the two stepper motors whose backs are going to be facing perpendicular to the ground.
Step 7: 3D Printed Parts: Stepper Motor Casing 2
This casing is designed for the single stepper motor that is going to be placed in the back of the lock box with its back being parallel to the ground.
Step 8: 3D Printed Parts: Wire Collection Roller
This part of the 3D printed parts is going to be placed on the Stepper Motor that is placed parallel to the ground. It is designed specifically to fit with it and will be used to rail in the main drawer but also to allow it to be pulled out.
Step 9: 3D Printed Parts: Battery Holder
This part is meant to hold a battery pocket with an off and on switch. Please see the link further description on the battery pocket that I am referring to.
Amazon.com: 2 Pcs 2.1 x 5.5mm DC Plug 9V Battery Holder w Cover (for 1x 9V Battery): Home Improvement
Battery Holder
Step 10: 3D Printed Parts: Lid
Unfortunately, the CAD file for this part was corrupted and I am not able to upload anything for it. However, you can take measurements from the Body file and create a replacement lid with ease. The only thing that is of note is the fact that the LCD display is going to be centered on the Lid at the top and that the holes for the screws for the LCD display case need to fit accordingly through the Lid. For this, you can take all necessary measurements from the LCD display case file.
Step 11: 3D Printed Parts: LCD Display Housing
This is a 3D-designed part to house the LCD display with the I2C bus attached on the back. In the design, I have created a slot to pull the cables through the housing designed specifically to allow for the cables to reach the Arduino Mega.
Step 12: 3D Printed Parts: LCD Display Cover
This part is designed to go hand-in-hand with the LCD Display Housing. This piece will go over the actual LCD in a fitted fashion and from there, these two parts will then fit precisely in the LCD Display Housing.
Step 13: Assembly of 3D Parts
Here I have included a few images for guidance on the assembly of the 3D parts. Alongside that I have included the step file for the assembly that I made strictly for the 3D printed parts.
NOTE: The Arduino is going to go beneath the battery holder and the RFID sensor goes just beneath the Stepper near the center of the body. The Arduino is being held by the 3 longer screws, everything else is screwed in with the other screws.
Step 14: Assembly of Electronic Components
Here I have included Fritzing diagrams for all of the electronic components individually. The reason for doing this is to not overcomplicate a single Fritzing diagram. For the Fritzing diagram with the LCD Display, I tried to imitate the I2C bus attachment on my LCD and then showed the wiring for that. The first image is the Fritzing diagram for the 6 touch sensors. The Fritzing diagram with the RFID sensor is imitating the RC522 RFID sensor that I have.
Step 15: Discussion About Arduino Code
Provided is the full code for the system that I have created. In it I have created comments which are specified by " // " and talk about why I used what I used and what the functionality of every command is.
