Introduction: The MacGyver LightBox/Softbox
A lightbox in photography it's like a blender in cooking. Sure you can do without it, but really? Can you? And obviously the results are much much better.
Wether you liked my analogy or not, a lightbox makes better and prettier photos. Here is how I did one in just a few minutes, out of an emergency (or because someone dropped the lightbox on the floor in the middle of the shooting, breaking in a kabillion pieces ¬¬), and using already available materials around the house/studio.
I attached some photos using this lightbox, so you can see the end result in the photograph. No other light source was used in the attached photos.
Step 1: Materials
You can replace everything here with whatever materials you have in hand, this is just like a guideline.
- 2 CFL Bulbs. I used 20W ones (Equivalent to 60W of incandescent ones.)
- 1 large container.
- 2 sockets for the bulbs.
- 2 electric plugs for the sockets.
- Aluminum paper.
- Cable.
Tools:
- Cutting tool. I used a dremel.
- Any glue.
- Electric juice... obviously.
- Aluminum paper.
- Cable.
Tools:
- Any glue.
Step 2: MacGyverishhh.
Drill/Cut 2 holes the size of the sockets in the container. Try to make them centered and evenly, just large enough for the socket to stay in place.
Cover the large container with aluminum, only the inside, no need to cover it entirely. Then just break the aluminum that's in the holes.
Step 3: Socketing.
Place the 2 sockets in the holes you just drilled. Glue them to the container.
NOTE : Place the sockets in a way that they don't "stick out" on the inside of the container.
Step 4: Shoot Away John.
Place the bulbs in their respective sockets and YOU. ARE. DONE!
I used only 20W with each CFL, for a total of 40W (120W incandescent). Professional lightboxes go around the 2000W incandescent, but this will get you going, enough to finish a shoot, or for normal use.
The more CFL's you use, the more light of course. You can use 40W CFL's (120W equivalent for incandescent), or even those 60W bad ass CFL's. Or use nine 20W CFL's in a container. It's up to you, this worked perfect for me.
Have fun!
Have fun!
