Introduction: The Magic Treasure Chest
This is an automatic chest opener
Step 1: Base
Build a base out of wooden cardboard
Use glue to hold the sides up
The height is 20cm long
The length of the base is 17cm long
The length of the box is 12cm long
Step 2: Server Motor
Add the server motor to the back of the box
Plug it into box 12
Slide it into the side of the box
Step 3: Lever
This is the lever that is going to open and close the chest
Step 4: Program
'-----[ Variables ]------------------------
irDetectLeft VAR Bit
irDetectRight VAR Bit
robot VAR Word
'-----[ Initialization ]--------------------
DEBUG "Testing piezospeaker..." 'let you know if it works
FREQOUT 4, 2000, 3000 '
DEBUG CLS,
"IR DETECTERS", CR,
"Left Right", CR,
' -----[ Main Routine ]---------------------
Do ' start of forever repeat loop
FREQOUT 8, 1, 38500 'sends out a infrared light
irDetectLeft = IN9 ' the variables
FREQOUT 2, 1, 38500 'sends out a infrared light
irDetectRight = IN0 ' the variables
FOR robot = 1 TO 120
PULSOUT 12, 850 'FWD
NEXT
IF (irDetectLeft = 0)THEN
PULSOUT 12, 650 'FWD
NEXT
ENDIF
IF (irDetectRight = 0)THEN
NEXT
ENDIF
FOR robot = 1 TO 24
PULSOUT 12, 850 ' turn right
PAUSE 20
NEXT
ENDIF
IF (irDetectRight = 0) THEN
FOR robot = 1 TO 25
PULSOUT 12, 850 'turn right
PAUSE 20
NEXT
ENDIF 'end of conditional statent
LOOP'end of forever repeat loop
